Spacers between shock tower and body 92/2000 civic needed.
Does anyone have information where I may find 2" spacers for the top of the shock towers to fit on the standard "top hats" and using the oem mounting holes.
I have Koni 1150 ajustable coilover shocks/springs but find they needed to be screwed up tight making the ride harder than I want and the shock travel is too limited and "tops out" when I hit a bump sometimes.
Reason for asking is i replaced the 14" wheels with high profile 15" wheels/tires to obtain higher final drive and better gas milage for a daily driver del Sol.
This is what I eventually decided on. A little lathe work and there we have it.
No REDKNECK comments please.
Modified by itsmejto at 5:44 AM 11/2/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itsmejto »</TD></TR><TR><TD CLASS="quote">Does anyone have information where I may find 2" spacers for the top of the shock towers to fit on the standard "top hats" and using the oem mounting holes.
you mean the shocks "bottom out"? if they do then thats bad news...they shouldnt do that...did you lower your car? spacers will not do anything...or are you talking about your tires hitting your wheel well liner? b more specific
do you mean extended top hats?
https://honda-tech.com/zerothread?id=2187584
No, I can't use top hat extensions, but nice work on those.
I want to space between the top hat and body with both shock and spring together.
An aluminium donut spacer is what I want, sometimes called a lift spacer.
Picture a donut with holes drilled in it for 10mm bolts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itsmejto »</TD></TR><TR><TD CLASS="quote">No, I can't use top hat extensions, but nice work on those.
The studs on the OEM upper shock mount won't be long enough with a spacer in there, will they?
You might need to do something that you can bolt to the upper shock mount, and then have that piece bolt to the chassis.
Alternatively, consider a coil spring spacer:
mastat89
Jan 18, 2013 10:41 PM
rhgindc
May 16, 2008 01:01 PM
LsDecepticon
Jan 13, 2008 05:41 AM
mikeunreal
16
Oct 27, 2005 06:40 PM
