95 LS turning over, but no start.
Old Oct 29, 2008 | 12:58 PM
Byaaah!'s Avatar
Jet Life Til' The Next Life
Default 95 LS turning over, but no start.
So I have a 95 LS that I haven't started in about a year.
I bought the distributor cap thinking that might be it.
I've been told the ECU is done. How would they have known anyways. I'ma use my buddys ECU from his LS/VTEC EM1 to atleast get it started.
What else would make the car just turn over and not start?
Thanks.
Old Oct 29, 2008 | 01:15 PM
neardon's Avatar
I'm a Jackass
Default Re: 95 LS turning over, but no start. (Byaaah!)
Check for spark and fuel. If its turning over and not starting its probably one of those. No fuel could be the main relay or the fuel pump or maybe but least likely it could be the ecu. If you dont have spark then its probably the coil or ignitor. You can check to see if those are still good with some basic tools and a manual for your car. If you dont have a manual then google "hondahookup manuals". Hope this helps.
Old Oct 29, 2008 | 01:25 PM
Byaaah!'s Avatar
Default Re: 95 LS turning over, but no start. (neardon)
Fuel pump primes so that means it would be getting fuel correct?
And is there any way to see if the main relay is good? Its kinda hard to tell if its bad.
Thanks for the help.
Old Oct 29, 2008 | 01:36 PM
stocker2shocker91's Avatar
I requested a short story for a title.
does it smell like gas?? if it has sat for a long time alot of sediment in the tank could have settle to the bottom and gotten sucked into the fuel filter and clogged it up.
Old Oct 29, 2008 | 01:37 PM
Byaaah!'s Avatar
Default Re: 95 LS turning over, but no start. (stocker2shocker91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stocker2shocker91 &raquo;</TD></TR><TR><TD CLASS="quote">does it smell like gas?? if it has sat for a long time alot of sediment in the tank could have settle to the bottom and gotten sucked into the fuel filter and clogged it up?
In the process of it turning over, yes, I smelled gas.
Old Oct 29, 2008 | 01:40 PM
neardon's Avatar
I'm a Jackass
The only true way to tell if your getting fuel is to see if its getting on the spark plugs. If you have been trying to turn it over quite a few times all 4 spark plugs should have a noticiable amount of gas on them. The injectors could still be stuck open or not letting enough gas in but thats not likely. If you are getting fuel then your relay is good.
Old Oct 29, 2008 | 01:41 PM
hmmm. how do the plugs look?
Old Oct 29, 2008 | 01:43 PM
Byaaah!'s Avatar
I'll be able to check the spark plugs when I get my tools back
Well before my car ever died. The problem was that it would cut off randomly like at a red light. It did that for about 2 days and then all it did was turn over.
Old Oct 29, 2008 | 01:46 PM
does it do any kinda of firing? like maybe one or two cylinders every now and then? or just nothing
Old Oct 29, 2008 | 01:48 PM
Byaaah!'s Avatar
Well before it died, it misfired but I changed the plugs and wires and that fixed that problem. But now, it turns over and thats all it does.
Old Oct 29, 2008 | 01:53 PM
well you might have to just wait till you get your tools back then, there is not to much you can do without bein able to check the plugs. i would let it sit for awhile cause chances are its flooded by now..
what is the cel doin?
Old Oct 29, 2008 | 02:17 PM
Byaaah!'s Avatar
what is the cel doin?</TD></TR></TABLE>
No CEL.
Old Oct 29, 2008 | 02:21 PM
if you know someone that would let you borrow there dizzy to see if that fixes it that would be nice. but i would assume since there is no cel all systems in it are working properly.
when you turn the key on does the cel come on then shut off at least? or just not come on at all like you said.
Old Oct 29, 2008 | 02:27 PM
Byaaah!'s Avatar
I'ma ask my buddy with the LS/VTEC EM1 if I can use his, but that won't be until tomorrow since he gets off at 1am.
I turned the key and all the cluster lights came on, then the CEL turned off like usual.
Old Oct 30, 2008 | 05:50 AM
neardon's Avatar
I'm a Jackass
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stocker2shocker91 &raquo;</TD></TR><TR><TD CLASS="quote">if you know someone that would let you borrow there dizzy to see if that fixes it that would be nice. but i would assume since there is no cel all systems in it are working properly.
https://honda-tech.com/zerothread?id=978933
There is the list of codes. I was just wondering what one would he throw if something in his distributor went bad, or were you just pulling that info from your ***?
Old Oct 30, 2008 | 08:27 AM
Byaaah!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neardon &raquo;</TD></TR><TR><TD CLASS="quote">
There is the list of codes. I was just wondering what one would he throw if something in his distributor went bad, or were you just pulling that info from your ***?</TD></TR></TABLE>
It didn't throw a CEL.
But I get my tools today so I can check the plugs.
Old Oct 30, 2008 | 11:55 AM
Byaaah!'s Avatar
I'm not getting any spark.
Old Oct 30, 2008 | 11:59 AM
neardon's Avatar
I'm a Jackass
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Byaaah! &raquo;</TD></TR><TR><TD CLASS="quote">
Yea I was just tryin to prove that other guy is dumb and that he is just tryin to spread false info.
No spark its probably going to be the coil or ignitor. Both are inside the distributor. Get a manual and check it out.
Old Oct 30, 2008 | 12:26 PM
Byaaah!'s Avatar
Is there a way to test any of those two?
Old Oct 30, 2008 | 12:56 PM
neardon's Avatar
I'm a Jackass
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neardon &raquo;</TD></TR><TR><TD CLASS="quote">Check for spark and fuel. If its turning over and not starting its probably one of those. No fuel could be the main relay or the fuel pump or maybe but least likely it could be the ecu. If you dont have spark then its probably the coil or ignitor. You can check to see if those are still good with some basic tools and a manual for your car. If you dont have a manual then google "hondahookup manuals". Hope this helps.</TD></TR></TABLE>
651DelSol
Aug 21, 2013 09:51 AM
FoRizzyy
May 12, 2012 09:41 AM
boosted423
Aug 4, 2008 08:20 PM
Pure_Lude
Aug 11, 2007 11:38 AM
Phil McConkey
Feb 25, 2007 07:42 PM
