Need complete clarification: What seats bolt directly into a 91 hatch?
Old Oct 29, 2008 | 12:18 PM
hushypushy's Avatar
Default Need complete clarification: What seats bolt directly into a 91 hatch?
Ok, so I've done a bunch of searching and this is what I have concluded about seat compatibility, mainly based on this thread.
Which seats fit into my 1991 Si?
88-89 hatch: NO
90-91 hatch: YES
88 CRX: NO
89-91 CRX: ??? (probably not, but one person in the other thread says he did it)
88-91 JDM hatch: NO (only fit in 88-89 US?)
88-91 JDM CRX: NO
INFORMED input is appreciated; armchair mechanics, please don't talk out of your ***. I'm looking for someone who knows the info for a fact, hopefully because you have the specific seats in question in your 90-91 hatch.
If worse comes to worse, I know I can just take my current seat apart and put any EF seat in there by reusing the seat pan and rails, but I'd rather get something that bolts in so I can sell my current seats
Old Oct 29, 2008 | 02:01 PM
jdmallmotorhatch's Avatar
well i know that 88-89 and 90-91 is slightly different.. now rather its different between a hatch and crx im not real sure. just one thing im missing in this thread, what seats are you wanting to get (oem honda seats, sparco, recaro etc)? now just something i was told not long ago, 88-91 years seats will fit in all 4 years of the hatch but one of the rear bolts will have to be shimmed... im curious to see others inputs on this as well...
Old Oct 29, 2008 | 02:38 PM
hushypushy's Avatar
Default Re: (jdmallmotorhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmallmotorhatch &raquo;</TD></TR><TR><TD CLASS="quote">just one thing im missing in this thread, what seats are you wanting to get (oem honda seats, sparco, recaro etc)? </TD></TR></TABLE>
Sorry, I didn't make it 100% clear. I'm talking only about OEM 88-91 Honda seats and nothing else. Although if I could find the right rails for Recaro SRD/SRII's, I'd probably put one of those in
Old Oct 29, 2008 | 03:40 PM
Nutnwrench's Avatar
Default Re: (hushypushy)
I know that the 90-91 civic seats will not fit into a 91 CRX because I had to do a pan swap to get the right rails. The CRX has a rail that runs on it's side instead of on it's base like your civic rails and they rails aren't interchangable so that's the reason for the pan swaps i've found
Old Oct 29, 2008 | 04:43 PM
elliot's Avatar
Default Re: (Nutnwrench)
does anyone know if seats from a 3rd gen prelude will fit in my 91 civic Si? and how about the rear seats? thanks
hushypushy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nutnwrench &raquo;</TD></TR><TR><TD CLASS="quote">I know that the 90-91 civic seats will not fit into a 91 CRX because I had to do a pan swap to get the right rails. The CRX has a rail that runs on it's side instead of on it's base like your civic rails and they rails aren't interchangable so that's the reason for the pan swaps i've found</TD></TR></TABLE>
pm'd
Old Oct 29, 2008 | 04:50 PM
EFstyle's Avatar
Default Re: (elliot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elliot &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know if seats from a 3rd gen prelude will fit in my 91 civic Si? and how about the rear seats? thanks</TD></TR></TABLE>
not too up on ludes... 3rg gen as in before or after 97?
Old Oct 30, 2008 | 10:24 AM
hushypushy's Avatar
bump
Has anyone put CRX or JDM EF seats in their 90-91??
Old Oct 30, 2008 | 10:46 AM
jdm.I.am's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hushypushy &raquo;</TD></TR><TR><TD CLASS="quote">bump
Has anyone put CRX or JDM EF seats in their 90-91??</TD></TR></TABLE>
yes, i have jdm ef9 front and back seats in my 91 si hatch and they fit fine, all i did was drill the bolt holes on the 2 front seats just a little bit bigger... i was also using 00 integ gsr front and back seats in my hatch as well.. they fit with just a little modding to the rails.
Old Oct 30, 2008 | 11:09 AM
hushypushy's Avatar
Default Re: (jdm.I.am)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm.I.am &raquo;</TD></TR><TR><TD CLASS="quote">
yes, i have jdm ef9 front and back seats in my 91 si hatch and they fit fine, all i did was drill the bolt holes on the 2 front seats just a little bit bigger... i was also using 00 integ gsr front and back seats in my hatch as well.. they fit with just a little modding to the rails. </TD></TR></TABLE>
Do you have any pics? Which bolt holes did you have to modify? I'd like to know just how different EF9 bolt holes are from 90-91 US bolt holes...
Old Oct 30, 2008 | 11:50 AM
jdm.I.am's Avatar
i dont have any off hand of the mods but i drilled all 4 bolt holes bigger but dont think i needed to... im off work at 6 and ill snap some pictures of the seat brackets for ya.
Old Oct 30, 2008 | 12:16 PM
JaY*JunKiEs*CrEw's Avatar
90 INTEGRA'S SEATS FIT ALSO ANY EF SEAT'S AS WELL THE EG/EK/AND DC ONLY BOLT UP TO 3 HOLES
Old Oct 30, 2008 | 02:00 PM
Type-R32's Avatar
what if you have a 91 dx hatch, is it the same as the si?
Old Oct 30, 2008 | 03:10 PM
hushypushy's Avatar
Default Re: (Type-R32)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type-R32 &raquo;</TD></TR><TR><TD CLASS="quote">what if you have a 91 dx hatch, is it the same as the si?</TD></TR></TABLE>
Yes, it should be.
Keep in mind you're in Canada, and AFAIK like the JDM models, 88-91 have the same seats for you guys since you don't have door mounted seatbelts.
Old Oct 30, 2008 | 03:40 PM
89s1's Avatar
Yes, it should be.
Keep in mind you're in Canada, and AFAIK like the JDM models, 88-91 have the same seats for you guys since you don't have door mounted seatbelts.</TD></TR></TABLE>
You are correct. I just installed 90-91 si seats in my 91 dx using one 91 seatpan and one 89 seatpan.
Old Oct 30, 2008 | 08:20 PM
elliot's Avatar
by 3rd gen i mean like the ones in the early 90's. i'm not too up on ludes either but the seats i'm looking at are out of a 91 i think
Old Nov 7, 2008 | 10:33 AM
wakaranai's Avatar
Pan's Labyrinth.
Old Nov 7, 2008 | 11:05 AM
89s1's Avatar
Default Re: (wakaranai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wakaranai &raquo;</TD></TR><TR><TD CLASS="quote">Pan's Labyrinth. </TD></TR></TABLE>
Pretty old thread to be bumping with something as lame as this...
Do better.
Old Nov 7, 2008 | 02:54 PM
hushypushy's Avatar
Originally Posted by wakaranai
Pan's Labyrinth.
I'm not laughing now......but I'm sure I'll feel that way when I make you help me do a pan swap
Old Nov 7, 2008 | 05:37 PM
wakaranai's Avatar
Wow this thread is ancient. Just over a week old!!
Yeah, disassembling seats...that is some fun right there.
Old Nov 7, 2008 | 06:12 PM
hushypushy's Avatar
Now that will be a pan...........labyrinth
Old Nov 13, 2008 | 12:58 PM
audiopipematt88's Avatar
Default Re: Need complete clarification: What seats bolt directly into a 91 hatch? (hushypushy)
i dont think anything but srx seats will fit... the civic seats are close..
gassaversracing
10
Apr 29, 2009 10:38 AM
square_1
Jun 17, 2007 05:15 AM
Ilovemyef9
Mar 19, 2007 02:59 PM
Civic89stdB16
Feb 13, 2007 06:10 AM
claytonsmith
20
Jun 1, 2004 04:06 AM
