car jerks at about 1500 rpm all gears
Old Oct 29, 2008 | 08:22 AM
Boostn B20's Avatar
Default car jerks at about 1500 rpm all gears
hey. i went out for a test drive, i noticed my car jerks at about 1500 rpm, after that, once u get to 2800-3000 it stops. wat cud that be. i think i bled my clutch line properly, cud it be spark plugs bad, but they look good...any ideas? if it has happened to anyone else....
Old Oct 29, 2008 | 09:26 AM
Ladiesx3Me's Avatar
Any codes being thrown?
Sounds like it could be a tps problem or a misfire issue.
Does it jerk once or does it just sound liek its jerking and sputtering?
More info on the car too
Old Oct 29, 2008 | 09:35 AM
90Rexx's Avatar
Default Re: (Ladiesx3Me)
give us the whole story...you said test driving....test driving for what exactly?
Old Oct 29, 2008 | 07:19 PM
Boostn B20's Avatar
nah. test driving because i jus did my z6 swap. i placed my old tranny on the new motor. it's a continuos jerk tho. so i was test driving, to make sure my car does not overheat , because i 've been having that problem.it's a 95 ex wit d16z6 motor.stock
Old Nov 2, 2008 | 07:51 AM
Boostn B20's Avatar
anybody got any update on what this problem might be?
Old Nov 2, 2008 | 08:02 AM
wrenchez81's Avatar
Default Re: (Boostn B20)
.........clutch chatter???
Old Nov 2, 2008 | 08:13 AM
Boostn B20's Avatar
???cluth chatter? my bad.
Old Nov 2, 2008 | 08:30 AM
wrenchez81's Avatar
are u asking what this is??
Old Nov 2, 2008 | 08:32 AM
Boostn B20's Avatar
yea. sorry
Old Nov 2, 2008 | 08:38 AM
wrenchez81's Avatar
das coo..... its when you load your clutch up like 4th gear doin 30mph... u will get this jerking sensation and what it is , is the clutch disc skippin accross the hardspots on the flywheel, the clutch slipping and then gripping causes it to chatter... try this... keep your load off the clutch,, for example keep your rpms over 2800 in all gears and see if the problem goes away........
Old Nov 2, 2008 | 08:40 AM
wrenchez81's Avatar
Default Re: (wrenchez81)
did u check ur post about the coolant temp sender????
Old Nov 2, 2008 | 08:42 AM
Boostn B20's Avatar
nah. its not that. ight. example. im taking off in 1st gear. and im not drilling it, so i rise up 1200-1300-1400-1500 then it jus starts jerking once i pass the 1500 and go into the 2000 for ex. it stops and wen i shift into 2nd if it falls down to 1500 it starts jerking again, all the way up to i think 3rd gear is wen it stops. but i think it did do it once in 3rd.
Old Nov 2, 2008 | 08:45 AM
wrenchez81's Avatar
u might have a flat spot in the tps... do u know how to check this?
Old Nov 3, 2008 | 04:34 PM
Boostn B20's Avatar
no. how do i check it?
Old Nov 3, 2008 | 07:52 PM
EkFG's Avatar
did you mess with the distributor ?
Old Nov 3, 2008 | 07:57 PM
Hill4589's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrenchez81 &raquo;</TD></TR><TR><TD CLASS="quote">das coo..... its when you load your clutch up like 4th gear doin 30mph... u will get this jerking sensation and what it is , is the clutch disc skippin accross the hardspots on the flywheel, the clutch slipping and then gripping causes it to chatter... try this... keep your load off the clutch,, for example keep your rpms over 2800 in all gears and see if the problem goes away........</TD></TR></TABLE>
I get that all the time haha, drives me nuts so i keep the RPMs up higher so it doesnt do that, i would tell you the RPMs but I dont have a tac haha. Anyways my clutch is beat and I just replaced wires plugs cap and rotor so dont worry about any of those. Hope this helps a little
Old Nov 3, 2008 | 08:26 PM
Boostn B20's Avatar
yea i had to take it out, and put it back in.cud that have something to do with it.(distributor)
strictly german
Transmission & Drivetrain
May 15, 2010 10:26 PM
LSRracing95
Feb 2, 2006 03:40 PM
EuRaZiAnRsXGoDDeSS
17
Nov 5, 2003 07:02 PM
2001TypeR
Aug 15, 2002 02:27 PM
Qwikrex
15
Jul 22, 2002 03:01 AM
