Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
JDM DC5 Type R Valve Cover, will it fit our K20Z3?
Old Oct 29, 2008 | 05:23 AM
06BlackSi #45's Avatar
Default JDM DC5 Type R Valve Cover, will it fit our K20Z3?
Wanted to pick up this combo along with the Black Dip Stick.
http://yhst-1408381693991.stor....html
Will this fit without any modifications? Thanks for the help. I also had no luck finding anything under search for this forum.
Old Oct 29, 2008 | 05:39 AM
C27A4's Avatar
Default Re: JDM DC5 Type R Valve Cover, will it fit our K20Z3? (06BlackSi #45)
it will fit just fine.
Old Oct 29, 2008 | 07:33 AM
Zeusone's Avatar
it will fit but it is missing the holes to screw in the wire mount on the right side of the valve cover. its better to get the stock valve cover powder coated but if you dont mind you can just zip tie them to something to keep them from moving.
Old Oct 29, 2008 | 08:12 AM
SIVIC 3's Avatar
i have the dc5 type R valve cover. fits perfect. go for it.
*also, didnt use any zipties? not sure what zeusone is referring too.
Old Oct 29, 2008 | 08:14 AM
Default Re: (SIVIC 3)
Cool, thanks for the help guys!
Old Oct 29, 2008 | 08:15 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIVIC 3 &raquo;</TD></TR><TR><TD CLASS="quote">i have the dc5 type R valve cover. fits perfect. go for it.
*also, didnt use any zipties? not sure what zeusone is referring too.</TD></TR></TABLE>
Hey SIVIC, can you post a pic of yours. Especially since your car is NHBP. Thanks in advance.
Old Oct 29, 2008 | 09:07 AM
SIVIC 3's Avatar
Old Oct 29, 2008 | 09:32 AM
Nice!! Thanks for the pics SIVIC. So on a scale of 1 to 10 how hard was the install? Did you use your old gasket or get a new one?
Old Oct 29, 2008 | 09:38 AM
JTaudio0212's Avatar
Default Re: (06BlackSi #45)
WOW, that looks really good, congrats
Old Oct 29, 2008 | 10:30 AM
K5^'s Avatar
K5^
Brand New
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 06BlackSi #45 &raquo;</TD></TR><TR><TD CLASS="quote">Nice!! Thanks for the pics SIVIC. So on a scale of 1 to 10 how hard was the install? Did you use your old gasket or get a new one? </TD></TR></TABLE>
There used to be a thread for installing this valve cover in the former FAQ section by BlueRocket. It seemed to be pretty straight forward. Does anyone have a link to the old FAQ?
Old Oct 29, 2008 | 10:39 AM
IT GUY's Avatar
Default Re: (K5^)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K5^ &raquo;</TD></TR><TR><TD CLASS="quote">
There used to be a thread for installing this valve cover in the former FAQ section by BlueRocket. It seemed to be pretty straight forward. Does anyone have a link to the old FAQ?</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1932651
You just have to search for archived threads created by Blue Rocket.
His images aren't there anymore, but there's a link to another DIY.
Between the two threads and SIVIC 3's pics, I'm sure you can figure it out.
Old Oct 29, 2008 | 10:40 AM
SIVIC 3's Avatar
install would be a 3/10. you need to remove the cowel and the upper metal subframe.
i used a new gasket. with honda-bondII on all curves and corners
Old Oct 29, 2008 | 10:41 AM
Default Re: (IT GUY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT GUY &raquo;</TD></TR><TR><TD CLASS="quote">
Between the two threads and SIVIC 3's pics, I'm sure you can figure it out. </TD></TR></TABLE>
Oh ok, so search archived. Yeah I just selected the current forums.
Old Oct 29, 2008 | 10:42 AM
Thanks again for all the help guys! I'll be doing this mod soon.
Old Oct 29, 2008 | 10:45 AM
K5^'s Avatar
K5^
Brand New
Thanks It Guy.
Campus Wifi is very intermittent. I tried searching, but connection kept failing.
Old Oct 29, 2008 | 02:03 PM
Power of Dreams's Avatar
I posted on 8th Civic forum.
The K20A CTR valve cover has "Honda Motor Co. Ltd." on it, based on Honda Japan's very own website.
So, unless your "CTR" valve cover has that, it's not actually authentic. But, if you're just looking for the wrinkle red, then it wouldn't matter.
Old Oct 29, 2008 | 03:00 PM
B16SolMan's Avatar
New User
That looks awesome--also a lot easier than painting the valve cover
Old Oct 29, 2008 | 04:08 PM
Default Re: JDM DC5 Type R Valve Cover, will it fit our K20Z3? (Power of Dreams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Power of Dreams &raquo;</TD></TR><TR><TD CLASS="quote">I posted on 8th Civic forum.
So, unless your "CTR" valve cover has that, it's not actually authentic. But, if you're just looking for the wrinkle red, then it wouldn't matter.</TD></TR></TABLE>
I thought that was only on the B Series Valve Covers??? Anyone???
Old Oct 29, 2008 | 04:18 PM
http://www.honda.co.jp/CIVICTY...e.jpg
Old Oct 29, 2008 | 04:30 PM
SIVIC 3's Avatar
the valve cover we are using is from the dc5 integra type R, not the civic type R.
i purchased the valve cover and coil cover from jdmland.com so its authentic. brand new in the box *made in japan*
Old Oct 29, 2008 | 04:35 PM
SIVIC 3's Avatar
https://honda-tech.com/zero...89032
half way down the page, read jdm.k20's post w/pic
Old Oct 29, 2008 | 04:49 PM
Default Re: JDM DC5 Type R Valve Cover, will it fit our K20Z3? (SIVIC 3)
i purchased the valve cover and coil cover from jdmland.com so its authentic. brand new in the box *made in japan*</TD></TR></TABLE>
I never said yours wasn't authentic. I said that if you think you have a CTR valve cover, yet it does not say "Honda Motor Co. Ltd.," then it's not authentic. This obviously does not apply to you because you have a valve cover from a DC5 ITR. I don't believe I quoted you, meaning that my comment was a general comment for everyone reading the thread.
I guess the reason I mentioned the CTR valve cover was because people say the DC5 ITR valve cover does not have holes threaded for the bracket on the side. Thus, people are letting those hoses hang freely or zip-tying them. That's one of the reason why I'm not really going to get the DC5 ITR valve cover, even though it does look very good on your car. I just want all the threaded holes to be on it. Kinda' picky like that. Perhaps the CTR valve cover does have the threaded holes. Not sure. Anyone know?
Old Oct 29, 2008 | 05:19 PM
SIVIC 3's Avatar
oh. sounded like you were callin me out. this thread is TITLED: DC5 type R valve cover , so not sure why your talking CTR? i have yet to see anyone use the actual CTR valve cover, maybe they are not readily available?
Old Oct 30, 2008 | 05:32 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIVIC 3 &raquo;</TD></TR><TR><TD CLASS="quote">oh. sounded like you were callin me out. this thread is TITLED: DC5 type R valve cover , so not sure why your talking CTR? i have yet to see anyone use the actual CTR valve cover, maybe they are not readily available?</TD></TR></TABLE>
Hmmm yeah I haven't seen any place carry a CTR valve cover. Wonder why that is...?
Old Oct 30, 2008 | 07:42 AM
Zeusone's Avatar
QUOTE=Power of Dreams]
I guess the reason I mentioned the CTR valve cover was because people say the DC5 ITR valve cover does not have holes threaded for the bracket on the side. Thus, people are letting those hoses hang freely or zip-tying them. That's one of the reason why I'm not really going to get the DC5 ITR valve cover, even though it does look very good on your car. I just want all the threaded holes to be on it. Kinda' picky like that. Perhaps the CTR valve cover does have the threaded holes. Not sure. Anyone know?[/QUOTE]
the ctr cover does have the threaded holes
