Installation of fuel tank fittings...
Finally i got all my fittings in for my fuel set up (yes i know its dirty, i ran out of simple green). I have a question though about the fuel lid return line though. First off, im going to rethread the 12mmx1.25 feed hole to a pitch of 12mmx1.5 so i can run a 8an feed line. Underneath the lid there is a copper tube i believe, did you guys just cut this off with a dremel?
Now for the return line im a little confused.
I assume you cut the stock tube (above and beneath the lid) using a dremel and drill a hole in the plate to one large enough to install the earls 90deg swivel fitting and stratoseal grommet, correct?
Below is a picture of Farnsrocket's Fuel pump return to give you guys an idea.
For the return fitting, do you run a hose like the stock one or do you guys just let it drain from the bottom of the earls fitting? All help is greatly appreciated. Thanks again.
[Modified by GudeH23a, 1:12 AM 7/30/2002]
Yep, cut off with a dremel as well as you can....it's tight in there, then drill it out big enough for the fitting. I am just letting mine drain from there. I wasn't worried about running another tube like the stock setup. Have fun.
Heres my pics if you didnt see them yet.
http://mywebpages.comcast.net/turboc...%20connection/ For some reason I am getting an error when opening--I think the site is down, but give it a try.
h22acivichybrid
Jun 14, 2004 03:20 PM
MarkosMotorsports
May 24, 2004 06:58 PM
