bench bleeding
Old Oct 29, 2008 | 01:20 AM
hawtsoss's Avatar
Default bench bleeding
how do i bench bleed a master clutch cylinder at home?
help is appreciated thanks
Old Oct 29, 2008 | 05:56 AM
mgags7's Avatar
use fittings to connect hoses to both the reservoir line and the line out to the rest of the clutch system.
insert both of those hoses into a jar of brake fluid, and slowly pump away until air bubbles stop coming out of the lines when you pump the piston.
Do your best to plug the holes so you don't get brake fluid all over everything, and don't accidentally push the piston at all when installing, or you'll get air back in it.
Old Oct 29, 2008 | 12:31 PM
hawtsoss's Avatar
ok would that work if i just submerged the cylinder in brake fluid and pumped the air bubbles out that way?
Old Oct 29, 2008 | 02:30 PM
slamdlude's Avatar
Default Re: (hawtsoss)
Every brake master cylinder I have ever bought has come with lines and instruction on how to do it, but if your didn't come with them here is a link. http://www.superchevy.com/tech....html It is the same process for a clutch master cylinder.
Old Oct 30, 2008 | 04:41 AM
mgags7's Avatar
you certainly could submerge the whole thing, but that will be a waste of a lot of brake fluid and a mess.
Old Oct 30, 2008 | 07:00 PM
hawtsoss's Avatar
i dont really care about wasting fluid anymore i have wasted so much it probably wont make a difference lol, but the guys in the other thread said i dont need to bench bleed it, so i am really confused
Old Oct 31, 2008 | 05:26 AM
mgags7's Avatar
you'll save yourself a good bit of hassle if you bench bleed first
Old Oct 31, 2008 | 07:35 AM
SKDRCR's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">
Do your best to plug the holes so you don't get brake fluid all over everything, and don't accidentally push the piston at all when installing, or you'll get air back in it.</TD></TR></TABLE>
Or you can just have a friend plug em with his fingers as you're depressing
the piston
Old Oct 31, 2008 | 07:45 AM
mgags7's Avatar
I wish I had friends.....
Old Oct 31, 2008 | 10:07 AM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">I wish I had friends..... </TD></TR></TABLE>
You do!!
&lt;----------------------Slides gagz a Newcastle
Old Oct 31, 2008 | 11:56 AM
mgags7's Avatar
hayyyyyyllll yea
thanks mang
35min to drinkdom
wait this isn't gdd....
Old Oct 31, 2008 | 04:00 PM
hawtsoss's Avatar
oh well the shop is paying to have it vacuum bled so i should be good in no less than a couple hours
autoxthis
Aug 22, 2008 06:11 PM
autoxthis
Honda Civic (2001 - 2005)
Aug 22, 2008 10:08 AM
autoxthis
Aug 21, 2008 11:12 PM
autoxthis
Aug 21, 2008 08:23 PM
justbelowme77
Mar 17, 2005 06:05 AM
