fuel pressure question
Old Oct 28, 2008 | 08:34 PM
BLU CIVIC's Avatar
Track Advocate
Default fuel pressure question
i swapped in a B16b into my hatch and want to know if i need to increase my fuel pressure. i already have a walbro 255lph fuel pump and have considered buying an AEM fuel rail and fpr...if i don't then great, money saved
Old Oct 29, 2008 | 05:44 PM
BLU CIVIC's Avatar
Track Advocate
no help?
Old Oct 29, 2008 | 05:46 PM
zrickety's Avatar
Default Re: (BLU CIVIC)
pretty sure you want 37-41 psi with the vacuum line detached. do you have a gauge?
unless you are going boosted, stock fuel pump, fuel rail and regulator should do the trick
Modified by zrickety at 7:52 PM 10/29/2008
Old Oct 29, 2008 | 06:11 PM
crispmofo's Avatar
Default Re: fuel pressure question (BLU CIVIC)
I just put a B18b in my EF and wanna know the same question. Should I upgrade my fuel pump?
Old Oct 29, 2008 | 07:31 PM
sgallagher's Avatar
Default Re: fuel pressure question (crispmofo)
Not necessary to upgrade fuel pump for a stock B-series. The stock pump will output enough fuel and the stock fpr will do what is necessary for the engine to receive the correct amount of fuel. If it concerns you install a fuel pump from a car with the same engine.
Old Oct 29, 2008 | 07:47 PM
BLU CIVIC's Avatar
Track Advocate
people were telling me that i needed to upgrade my fuel, which i didn't see a reason for...so unless i start modding the engine my fuel system is fine...thanks for the info
madcrx69
Aug 15, 2017 09:26 PM
95ITRJDM
Apr 10, 2011 06:09 AM
iNetForce
Nov 13, 2005 08:27 PM
Red D Dragon
Apr 3, 2004 06:53 PM
Brian_92GSR
Oct 25, 2001 11:27 AM
