New Injectors Needed?
Ok. heres the deal, on my 94 integra LS, if i tap the gas pedal repeatly, my car will shake badly, and i let my friend drive my car today and he said i need new injectors? what do you guys think? also where can i find some good prices on them?
thanks
thanks
There are many things you can do before replacing your injectors. Try do a full engine tune up and inspection to see if the condition improves. A good tune up can make your car run like new again.
Exactly, replace your plugs wires and run a fuel induction cleaning system. ( run the cleaner before you swap your plugs and wires though, it will foul them out real fast ) also might check your 02 sensor after the tune up if the problem still occurs. Just to me it sounds like the ignition.
Good Luck
Good Luck
yusoslo
Sep 25, 2004 07:41 PM
Zeus
Mar 29, 2003 10:40 PM
