pro's & con's for having a knife-edged crank ?
Old Jul 29, 2002 | 08:31 PM
nwarp's Avatar
Default pro's & con's for having a knife-edged crank ?
I know a few pro's for having a knife-edge'd crank are, picks up quicker and cuts thru the oil better...what are more pro's & con's if any ?
im considering picking up a knife-edge'd LS crank already balanaced by JG for 250 is it worth it ?
Old Jul 30, 2002 | 07:08 AM
Evil DOHC's Avatar
Default Re: pro's & con's for having a knife-edged crank ? (NA DC2)
Thats a pretty good price. Just the machine work would cost that much, but you still need to get it balanced for the pistons, rods, clutch, crank pulley, flywheel, etc. that you are going to use on your build up.
EVIL
Old Jul 30, 2002 | 08:27 AM
Suprdave's Avatar
uhm, ina honda...the crank isnt sitting in oil. so knife edging wouls be used primarily to lighten it.
Theres the whole Weight vs Strength Debate...
Personally, I would buy a used crank...unless you can inspect it beforehand.
Suprdave
Old Aug 1, 2002 | 01:36 PM
JDM CRX's Avatar
Default Re: pro's & con's for having a knife-edged crank ? (Suprdave)
i know in the b18c1 engines they have a windage tray,, which prevents the oil from getting smacked around by the crank, the purpose of knife edging a crank,besides the wieght aspect, is so it can cut through the oil when/if it should hit the crank without slowing the engine down or airating the oil. if the LS has a windage tray, i wouldnt bother knife edging it unless you just wanted less rotational weight, which will help you. just my 2 pennies.
[Modified by JDM CRX, 10:38 PM 8/1/2002]
Old Aug 2, 2002 | 10:44 AM
Suprdave's Avatar
Default Re: pro's & con's for having a knife-edged crank ? (JDM CRX)
All B-series motors have windage trays.
Suprdave
greyEG
16
May 22, 2013 01:38 AM
zakura R
Oct 13, 2010 06:55 AM
eg rookie
Nov 9, 2009 02:43 PM
95dcsleeper
Sep 5, 2005 06:48 PM
NERV
Sep 16, 2004 07:49 AM
