JDM Center Audio Console
Alright I've looked around a bit but couldn't find any real help.
I wanted to know how to Install your radio correctly in the Audio Console
My Radio is just pushed in it and Sleeve that came with the radio doesn't fit in it at all
I would like to get my radio in correct so any help your be great full
If I remember correctly you need to get an aftermarket mounting kit and pocket for an older accord (late eighties? I think) I put the stereo in a friends, this was before I was even aware there was a mounting kit and I used a combination of plastic zip ties and self threading screws. Sorry I don't have any pics.
Here's some photos I have saved of the console.
So according to that second image, there should be instructions from Honda. Go to Honda and ask for the instructions to install the optional audio console. They will print them out for you for free.
Since there is a US version they can print it for you anywhere in the US.
Here is a part number in case they can't find it (it's listed as "ACCESSORIES - ELECTRICAL in the parts catalog).
CONSOLE L. (*NH1* (BLACK))
08U60-SR0-112A
08U60-SR0-112A
here are the install instructions for the audio console, hope this helps.
http://www.hondaautomotivepart....html
you need an Accord din pocket. the optional CD player that goes there is 1/4 din size.
mine is from a 94-95 Accord, others should work just as well. you may/may not run into wire-cable issues if you mount the radio on top of the pocket. you can just mount the radio under it then.
with the OEM tape deck and add on slave cd player.
now with the 99-00 Si player and Accord pocket
Modified by NastyHabitzCRX at 1:01 AM 11/3/2008
o0oitsthaitea
Feb 20, 2009 11:00 AM
