obd-0 sohc zc intake manifold on a 99 y8 head will it work..? searched no results help
Old Oct 28, 2008 | 12:10 PM
anotherstar_noz's Avatar
Default obd-0 sohc zc intake manifold on a 99 y8 head will it work..? searched no results help
i have a obd0 zc single cam in my rex and im swapping in a mini me z6 block y8 head and want to kno before i remove my engine if my zc intake manifold will fit on the y8 head witout problems ? and /or wat manifold i need to get....any help appreciated
Old Oct 28, 2008 | 12:52 PM
Red_ED8's Avatar
Default Re: obd-0 sohc zc intake manifold on a 99 y8 head will it work..? searched no results help (another
Are you swap in a Z6 block with a Y8 head or are you doing a mini me? I would just swap the Y8 head on your zc block, use your zc mani, and call it a day.
Old Oct 28, 2008 | 10:43 PM
HaulingAddison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_ED8 &raquo;</TD></TR><TR><TD CLASS="quote">Are you swap in a Z6 block with a Y8 head or are you doing a mini me? I would just swap the Y8 head on your zc block, use your zc mani, and call it a day.</TD></TR></TABLE>
Won't work. OBD0 uses a more square looking water port on the intake manifold and OBD2 is round. You'll loose water because the water jacks won't line up. Had a D15B2 with OBD0 intake running the Y8 head. Never got the gasket to seal so it just overheated over and over and over again
Old Oct 30, 2008 | 02:23 PM
r1ch1e's Avatar
That's what my setup is now. A zc bottom and y8 head. With si manifold. It runs fine
Old Oct 30, 2008 | 03:04 PM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HaulingAddison &raquo;</TD></TR><TR><TD CLASS="quote">
Won't work. OBD0 uses a more square looking water port on the intake manifold and OBD2 is round. You'll loose water because the water jacks won't line up. Had a D15B2 with OBD0 intake running the Y8 head. Never got the gasket to seal so it just overheated over and over and over again </TD></TR></TABLE> Huh? If I understand correctly than, a PM3 head (B2/B7/A6 Casting) using a Y8 intake manifold would also not work according to this logic.
Old Nov 2, 2008 | 01:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote"> Huh? If I understand correctly than, a PM3 head (B2/B7/A6 Casting) using a Y8 intake manifold would also not work according to this logic.</TD></TR></TABLE>
The Y8 head
The ZC intake manifold
So tell me, how are you going to make the circle water port match up with the square water port?
Old Nov 2, 2008 | 01:59 PM
AJxr's Avatar
noone has ever had that problem. im pretty sure if it was that big of a problem people wouldnt use y8 intake manifolds on all kinds of 88-95 heads. yes it will work. if you use a new gasket and tighten the bolts tight just like you would any other time.
Old Nov 2, 2008 | 06:07 PM
my crx has the stock si engine , so your saying the zc inatke manifold wont work but an si one will wat year si cus if you meant crx si then that makes no sense ...
wats the best manifold to use on my mini me z6 block and y8 head in an 91 crx converted to obd1...
Old Nov 2, 2008 | 06:25 PM
97ekb18b's Avatar
use the y8 manifold its alot better than the one you have now..
dryhopsux13
12
Nov 4, 2004 01:38 PM
90DX
21
Jul 23, 2004 11:56 AM
4gvtec
Oct 1, 2002 04:36 PM
