Building my DA
Old Oct 28, 2008 | 11:28 AM
felixjr18's Avatar
Default Building my DA
Hey jus wondering what lil things I can or should do to gain power but this is my only car so i'll need to be able to put it back together in time for work lmao! I want to get cams but is it worth doing now if I want to turbo it with summer? Im on a tight budget being that I really want this car turbo'd in time for summer but im bored and want more power.
Old Oct 28, 2008 | 02:41 PM
BoSox46GSr's Avatar
Default Re: Building my DA (felixjr18)
What does it have on it right now? I/H/E would be a start...
Old Oct 28, 2008 | 07:45 PM
felixjr18's Avatar
Default Re: Building my DA (BoSox46GSr)
Its the b18a1 with 185,xxx miles with 4-2-1 header, downpipe, high flow cat, jdm style exhaust, and cold air intake.
Old Oct 28, 2008 | 11:55 PM
KILLAB17VTEC's Avatar
Genetically Gay
upgrade for turbo parts.
Old Oct 29, 2008 | 08:46 AM
felixjr18's Avatar
Default Re: Building my DA (KILLAB17VTEC)
But if I do that shouldn't it be done all at once becuz I wouuld have turbo parts and no turbo till summer came around
Old Oct 29, 2008 | 09:32 AM
stocker2shocker91's Avatar
I requested a short story for a title.
your on a tight budget but want to be turbo by summer???? then dont do a thing to the car till your ready to boost. why buy and aftermarket intake and header when your just going to remove them?
Old Oct 29, 2008 | 11:18 AM
felixjr18's Avatar
Default Re: Building my DA (stocker2shocker91)
I actually bought the car wth everything besides the header downpipe and high flow cat and I bought those before I wanted to go turbo.. and the only other thing i'll be buying is a short ram intake since winter is coming.. what's the average cost of a basic turbo build? im looking to push at least 250 but 300 would be better plus its my daily so it would have to be reliable
Old Oct 29, 2008 | 12:21 PM
ProjectFlatline's Avatar
New User
Just take your time and don't rush a build. When you rush you miss little important things that you need and bam... your car is blown up. Get everything before you turbo. You can go ahead and do the cam gears. I doubt it'll make a noticeable difference though until the turbo build.
Old Oct 29, 2008 | 01:23 PM
Default Re: Building my DA (ProjectFlatline)
http://www.beesandgoats.com/bo....html
^^^^^this is the turbo guide^^^^^^^ read it, study it, do it.. tons of general turbo knowledge with G2 integra specific turbo guidelines too.
also check out http://www.g2ic.com.... tons and tons of info and cheap mods to make your car one off
and as for cams, what cams are you talking about? crower? those are mainly for adding after you have boosted or are building a serious NA build.
but you can throw in a set of b18b cams froma newer LS. i think there good for another 10hp or so(correct me if im wrong on that one)
Yomama182691
Mar 22, 2013 08:58 AM
got_boost16
Jan 23, 2006 07:27 PM
KC GSR
May 31, 2002 08:54 PM
usdm NA 429
Mar 8, 2002 06:23 PM
