Best gearbox for a D16z6 turbo?? Please help, in need of quick reply
My personal opinion in the 92-95 Civic Si/EX transmission.
Some people think that the longer the gears, the better for boost, but there is a limit to that and there is such a thing as having too tall of gearing. The DX tranny might not be too bad, but the CX/VX tranny would suck horribly as they are just too long.
People making 400+whp on boosted B series stuff prefer GS-R trannies and even those are shorter than any 92-95 Civic D tranny, so you have to figure that a D tranny can't be too short for a boosted D16Z6.
BTW:
You cannot tell what type of 92-95 D tranny it is by looking at the tranny code alone. They'll all be S20 no matter if it's the CX/VX, DX, or Si/EX tranny.
The way you tell a Si/EX tranny frok all the others is that just above the fill plug (big 17mm bolt by where the right CV inner joint sticks into the tranny) there will be a B000 cast in the tranny casing itself. A000 means it's the non-Si/EX tranny and the only way to tell if it's a DX tranny rather than a CX/VX tranny is to split the case and start counting teeth, and doing math.
An excellent D tranny page is Mista Bone's Page complete with gear ratios, etc.
BTW:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jimmy o. »</TD></TR><TR><TD CLASS="quote">dont forget the factory LSD D15B JDM trans the EX/Si are the best you can get here though</TD></TR></TABLE>
True.
I would suggest though that if you're going all out then the absolute best ever tranny would be the tranny out of the JDM EG Special/Anniversary Edition that came with an OBD1 DOHC ZC engine in it. That tranny has equal length axles with intermediate shaft (to reduce torque steer) and the factory LSD.
...but where are you going to find one?
Also I'd suggest the next best thing in the form of a 92-95 Si/EX box with a Quaife LSD in it.
True.
Thanks that helped alot. So the 92-95 is an s20? with a b000 code. Thats the one i want?
What about the s40?
What about the s40?
To add to the suggestion of the d15b... Thats what i have and its a good tranny. Perfect for the steets. But it redlines at 6500 rpm. A long tranny would be the best. Something out of like a 99 hatch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Champs32 »</TD></TR><TR><TD CLASS="quote">To add to the suggestion of the d15b... Thats what i have and its a good tranny. Perfect for the steets. But it redlines at 6500 rpm. A long tranny would be the best. Something out of like a 99 hatch</TD></TR></TABLE>
Sorry but the transmission has NOTHING to do with your redline. Your redline is set by the ECU itself.
Also your suggestion of a longer tranny from a "99 hatch" is too vague. A 99 hatch tranny is shorter than the 92-95 CX/VX tranny and the 96-00 HX 5-speed tranny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_turbo_wannabe »</TD></TR><TR><TD CLASS="quote">and how do you know... from the mista bone website. If your 5th gear is 0.702 or 0.750 if you dont know if its come from a sedan or a Hatch??</TD></TR></TABLE>
If you actually care about the 5th gear then it's a matter of pulling the case apart and literally counting the teeth on the 5th gear mainshaft and countershaft then doing the math (divide one by the other - can't remember, but if you do it both ways one way equals the exact 5th gear ratio
) to determine which one you have. Two actual gears make up the "5th gear" in the tranny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_turbo_wannabe »</TD></TR><TR><TD CLASS="quote">my gearbox came.... its got a A000 number on it. should i send it back? and make sure i get a B000?</TD></TR></TABLE>
Yes. Boosted or not those gears (even if it's the DX) are too long.
SuicideSlide
Jul 19, 2003 12:37 PM
