Not much torque and power starting off from stop on first gear.
Old Oct 28, 2008 | 04:28 AM
chickenwing's Avatar
Default Not much torque and power starting off from stop on first gear.
I was wondering if this is normal for honda's D16Y8 to slow off the start with the accelerator pinned to the floor on first gear.
Powertrain has no more than 600 miles after rebuild.
Old Oct 28, 2008 | 04:37 AM
instructor74's Avatar
Default Re: Not much torque and power starting off from stop on first gear. (chickenwing)
welcome to the gutless wonder of an na 4 cylinder
Old Oct 28, 2008 | 04:40 AM
95jeremie's Avatar
Default Re: Not much torque and power starting off from stop on first gear. (instructor74)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instructor74 &raquo;</TD></TR><TR><TD CLASS="quote">welcome to the gutless wonder of an na 4 cylinder</TD></TR></TABLE>
x2 ha ha
Old Oct 28, 2008 | 04:48 AM
tercel95's Avatar
Have you ever driven a honda before??
Old Oct 28, 2008 | 05:16 AM
Default Re: (tercel95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tercel95 &raquo;</TD></TR><TR><TD CLASS="quote">Have you ever driven a honda before??</TD></TR></TABLE>
first time
but the old Y7 motor seems to have a bit more guts off the start.
the Y8 seems to pull over 4K till redline.
Old Oct 28, 2008 | 05:56 AM
96 EX's Avatar
Default Re: (chickenwing)
Its a 1.6 litre man there isnt going to be ANY guts on it really. I've got a d16y8 also and untill vtec (5500?) its worthless lol. So your not the only one, there suppose to be like that. Best bet is to swap or turbo IMO. Goodluck!
Old Oct 28, 2008 | 08:12 AM
MadScientistMatt's Avatar
At what RPM are you getting it moving? They don't seem to wake up until 3,000 RPM at least, so if you're driving it like you have something like a GM Quad Four it isn't going to respond in quite the same way. OTOH, if you are getting the revs up and nothing happens, something may be wrong.
Old Oct 28, 2008 | 10:00 AM
95jeremie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chickenwing &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering if this is normal for honda's D16Y8 to slow off the start with the accelerator pinned to the floor on first gear.
Powertrain has no more than 600 miles after rebuild.</TD></TR></TABLE>
ok so I'll bite
is it a manual?
if so get a light weight fly wheel
7lbs if going NA
10 lbs if planning on boost
that will help you accelerate faster
reducing the rotating mass plays a big factor
but you don't want to go to light on a boost application
because just as you build rpm's faster they fall faster to
less rotating mass
in a boost application this can hurt by the rpm's drooping out of the boost range in between shifts (but can be less effected if transmission is re-geared... don't ask)
so the long story short
replace your flywheel and you will notice a difference
not anything major but it will be better
and use the opportunity to upgrade your clutch as well (action 2md )
Old Oct 28, 2008 | 05:00 PM
Default Re: Not much torque and power starting off from stop on first gear. (95jeremie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95jeremie &raquo;</TD></TR><TR><TD CLASS="quote">
ok so I'll bite
is it a manual?
7lbs if going NA
less rotating mass
and use the opportunity to upgrade your clutch as well (action 2md )</TD></TR></TABLE>
upgraded aluminum billet flywheel with a 6 puck clutch.
Old Oct 29, 2008 | 10:56 AM
96 EX's Avatar
I agree, I've also got a d16y8 w/ 7.5lbs fidanza flywheel w/ Stg2 centerforce clutch. Id say that was the best $300 I invested in that engine. Also I noticed a acceleration gain with the flywheel and also when I installed my Unorthodox underdrive pulley too. But as stated, its a 1.6litre and isnt going to have alot of getty up and go before 4K rpms.
Old Oct 29, 2008 | 11:05 AM
00b20vtecoupe's Avatar
Default Re: Not much torque and power starting off from stop on first gear. (96 EX)
wish i could punch my lil 4 cylinder in 2nd gear and not have it rip the tires to 9 grand i almost forget wat its like to have traction. swap the motor.
Old Oct 29, 2008 | 12:06 PM
93egSLEEPER's Avatar
sounds like a stock honda to me
Old Oct 31, 2008 | 04:29 PM
looks like I have no choice but to turbo it
Old Oct 31, 2008 | 04:52 PM
turbojdmhatch's Avatar
Default Re: Not much torque and power starting off from stop on first gear. (00b20vtecoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00b20vtecoupe &raquo;</TD></TR><TR><TD CLASS="quote">wish i could punch my lil 4 cylinder in 2nd gear and not have it rip the tires to 9 grand i almost forget wat its like to have traction. swap the motor. </TD></TR></TABLE> me a river JT hahaha just kidding dont you love having fwd?
Old Nov 14, 2008 | 05:03 PM
shifting gears at 4500 rpms is not very fuel efficient.
newbietuner_si
26
Jan 3, 2008 03:08 PM
THE GAME IS THICK
Jan 29, 2006 01:41 AM
lv6l
12
Jan 28, 2006 02:11 PM
mikeski38
12
Dec 23, 2004 03:22 PM
honda9369
Aug 16, 2004 06:18 PM
