Replaced secondary o2 and still getting code 65
Old Jul 29, 2002 | 07:02 PM
Qwikrex's Avatar
Default Replaced secondary o2 and still getting code 65
Ok I installed a new secondary o2 sensor and I'm still getting the same code 65 secondary o2 sensor code. Is there a fuse that might be blown tha is connected to the secondary o2? Also did I wire the new o2 in correctly? Green=signal ground, White2 signal, 2 black=heater. What could be wrong?
Old Jul 29, 2002 | 07:24 PM
DragII's Avatar
25 Year Member
Default Re: Replaced secondary o2 and still getting code 65 ([VTEC]TL)
are you using the stock cat?
Old Jul 29, 2002 | 07:33 PM
Qwikrex's Avatar
Default Re: Replaced secondary o2 and still getting code 65 (DragII-Sellout)
no, I'm using a test pipe but I'm not getting the catalyst effeciency code, I'm getting a secondary o2 circuit code.
Old Jul 29, 2002 | 08:23 PM
97hb's Avatar
Did you have to rewire or did it just plug in? There are 4 wires (2 white and 2 green). Just keep mixing and matching untill it works (sounds ghetto but works). Did you reset the ecu after you tried? What kind of 02 sensor you using, stock???
efhatch1991
Jan 26, 2013 07:05 PM
the jdmchop
May 23, 2006 11:26 AM
EF8IGHT
Jan 10, 2006 02:52 PM
2000fbp
Mar 18, 2004 09:12 PM
EG2 SiR
Mar 4, 2004 10:35 AM
