4 wheel disc swap
i gotta 95 eg.i want to know if someone could tell me where i get the 4 wheel disc brake assembly??also i gotta question, for a 15" wheel is there a "right'' offset to use???thanks.
'94 - '01 Integra, any model but ITR. The proporting valve and MC and brake booster must come from a non ABS model. You can also use a '91 EX master cylinder and then you wont have to change the brake booster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG8 »</TD></TR><TR><TD CLASS="quote">'94 - '01 Integra, any model but ITR. The proporting valve and MC and brake booster must come from a non ABS model. You can also use a '91 EX master cylinder and then you wont have to change the brake booster.</TD></TR></TABLE>
Why not an ITR? They'll work fine, plus you'll have the 5-lug bling factor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Specail Ed »</TD></TR><TR><TD CLASS="quote">Why not an ITR? They'll work fine, plus you'll have the 5-lug bling factor.</TD></TR></TABLE>
Thats exactly why I said anything but ITR, most people don't want to go out and buy a new set of wheels just to upgrade their brakes. But yes you're correct you can use ITR brakes, but you will need 5 lug wheels as well.
Thats exactly why I said anything but ITR, most people don't want to go out and buy a new set of wheels just to upgrade their brakes. But yes you're correct you can use ITR brakes, but you will need 5 lug wheels as well. </TD></TR></TABLE>
Really? I thought HT was all about being JDM and the bling factor.
Because it will cost 3-5 times more.
Corksil
17
Dec 15, 2020 05:44 PM
EJ2_B16
18
Jan 25, 2005 09:46 PM
EJ2_B16
Aug 20, 2004 02:34 PM
