would a slight bore be need on my B18A??
Old Oct 27, 2008 | 06:52 PM
shocker911's Avatar
Default would a slight bore be need on my B18A??
i have a B18A that im gonna boost the hell out of lol. a good friend of mine i are having a slight dis-agreement.
would i need to bore .5 over on a motor that was running that i dis-assembled and am going to put new pistons in? better safe then sorry or what? the walls looks good.
Old Oct 27, 2008 | 07:58 PM
Running925's Avatar
Default Re: would a slight bore be need on my B18A?? (shocker911)
dial-bore gauge and some visual would answer this question!
If your unsure, and don't have the proper tools, take it to your local machine shop.
Old Oct 27, 2008 | 08:07 PM
ABK's Avatar
ABK
Default Re: would a slight bore be need on my B18A?? (Running925)
the walls might look good, but for boost you need larger piston to wall clearances to compensate for expansion. Clearances are different between manufactures. At least hone it if your clearances are good.
Old Oct 27, 2008 | 09:21 PM
EkFG's Avatar
Default Re: would a slight bore be need on my B18A?? (ABK)
get it bore .20 (81.5)with .004 piston to wall clearance for that magnificent numbers of boost
Old Oct 27, 2008 | 09:24 PM
shocker911's Avatar
ill bore it to 51.5 just to make it on the safe side. thanks for all the help guys much appreciated
Old Oct 27, 2008 | 09:26 PM
ABK's Avatar
ABK
Default Re: (shocker911)
you mean 81.5mm
ahenscheid
Feb 3, 2012 11:09 PM
HUGATO2002
Apr 17, 2009 04:10 AM
boostedb20z
Feb 16, 2008 05:47 AM
crxsi16
Apr 20, 2006 11:01 AM
Turbo_Si
Aug 13, 2002 09:12 PM
