How do I bench test the window regulators?
Old Oct 27, 2008 | 06:09 PM
starion88esir's Avatar
Default How do I bench test the window regulators?
Did a search and came up empty. Also, there are four wires directly out of the driver's regulator and two on the passenger side, does anyone have a factory wiring diagram that shows what the wires are for.
Old Oct 27, 2008 | 07:30 PM
JDMekBoosted's Avatar
Default Re: How do I bench test the window regulators? (starion88esir)
well just an FYI idk if you did it or not but check the fuse under the dash you can find a diagram online or if you have it then check it i almost replaced the hole assembly switches everything because i couldnt figure out why it wasnt working and it was the fuse. i was stupid lol
Old Oct 27, 2008 | 08:20 PM
Default Re: How do I bench test the window regulators? (JDMekBoosted)
****, I forgot there's a main window relay fuse isn't there? Do you know where it's located exactly? My box doesn't have a cover.
Donkeeyyy
May 30, 2011 02:45 PM
jlowellintegra
Nov 25, 2010 04:23 PM
Mylinh
Sep 8, 2010 06:25 PM
B-serious
Jun 5, 2006 09:28 PM
d_mina
Jun 20, 2004 02:51 AM
