91 Integra power problem...
My 91 LS recently stopped working. Here's what happened..
Started the car at my friends house (which is a little more than a mile away). Turned the car off @ my house and when I tried to start it, all power went away. If i left the car alone for 30+ sec, power will return.
I tested the battery with my multimeter and it read 12.5 volts. I tested the 12volt wire @ the ignition harness, it read 9.4. When I cranked the starter, both my 12volt and ignition wire drop to 2.4 then rises again when I stopped.
I've checked my fuses, battery terminal and REPLACED my Main Relay & new battery. I'm running out of ideas and appreciate any real help. Thx..
Modified by GoCarInteg at 9:16 PM 10/29/2008
Did it sart for a second and die or did it just turn over and not start? Maybe main relay. Check these sites out. Mine dose the same thing sometimes and Im thinking it the main relay.
http://www.marklamond.co.uk/te...y.htm
and
http://www.tegger.com/hondafaq/mainrelay.html
and
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NorthWest94Teg »</TD></TR><TR><TD CLASS="quote">Did it sart for a second and die or did it just turn over and not start? Maybe main relay. Check these sites out. Mine dose the same thing sometimes and Im thinking it the main relay.
and
The car did not crank or anything.. it just died when I tried to start it.
I've already replaced the main relay and nothing happened. Thanks!!!
Any others?
and
Any others?
bullvii
Jul 8, 2010 02:42 PM
