Mini me questions
Old Oct 27, 2008 | 04:51 PM
96jdmciv's Avatar
Default Mini me questions
so i got a 96 dx manual , y7block and im going to put a y8 head and y8 mani on it and i have a 98 ex manual ecu but the mani that i got is a y8 auto and it does have a 3- wire icav will the ecu read that 3 wire icav thanks
Old Oct 27, 2008 | 04:56 PM
andoxviii's Avatar
Pictures are down, but information is still valid:
https://honda-tech.com/zerothread?id=735196
Old Oct 28, 2008 | 10:13 AM
96jdmciv's Avatar
Default Re: Mini me questions (96jdmciv)
any other help
Old Oct 28, 2008 | 10:30 AM
andoxviii's Avatar
This was written in that article:
"The throttle body is a possible point of difficulty, the easiest way is to use the Y8 throttle body and y8 IACV on the head. In order to do this with the y7 wiring harness, you will need to take two spade connectors and connect them to the two prongs on the male side of the IACV connector, the connect these two wires to the three-wire female plug on the y8 wiring harness, being sure to disregard the orange wire. You will need to swap wires A12 and A14, and then disconnect wire A13 from the plug at the ECU."
This doesn't answer your question?
Perhaps give a better explanation of your issue...
Old Oct 28, 2008 | 10:41 AM
andoxviii's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apotheosis &raquo;</TD></TR><TR><TD CLASS="quote">from what ive seen, if you want the y8 intake manifold, you need it from an automatc because the sensors wont be the same for your y7 if its from a manual car with the y8</TD></TR></TABLE>
I copied this over from another thread. Which means you probably can use the automatic head with no issues with your manual ECU.
Old Oct 28, 2008 | 11:10 AM
96jdmciv's Avatar
Default Re: (andoxviii)
also i have the p2p ecu and so ur saying that my y8 mani auto will work with p2p ecu because my harness is a 3 connector to the icav and and plug on tha mani is a 3 wire plug icav i just hope my ecu reads it
Old Oct 29, 2008 | 04:25 PM
96jdmciv's Avatar
Default Re: (96jdmciv)
anybody else
Crosseman
Jan 14, 2015 05:29 PM
Ryan Williams
Sep 12, 2014 06:54 AM
knightsef-eg
Apr 25, 2010 07:35 PM
SOLEpassion
Mar 10, 2010 04:26 PM
g2turbo
Jul 2, 2003 11:58 PM
