Having Some Idle/check engine light issues (P2227 Code)
Old Oct 27, 2008 | 04:47 PM
LSX-PWR's Avatar
Default Having Some Idle/check engine light issues (P2227 Code)
I really didnt want this to be my first post on here but i need to get some info like asap on this problem. I have a 04 Acura RSX Type-S. It has a Greddy turbo kit on it. Check engine light is on right now and it seems to be idleing really high. I work for a Honda dealer so i had the code pulled. Code was P2227 Baro Sensor Performance (Possible Failure) * ECM internal circuit failure
I did do a search and i found one thread relating to this problem. And one person suggested that it could be the MAP sensor that actually set a BARO code instead of a MAP code. Can anyone confirm this? I also read on one of our service bulletins that it could be possible the TPS is bad as well. Im wanting to buy this car and i can get it for a steal pretty much if i can fix this problem. So if you have any help that would be awesome caue im about ready to just go out and get a new map to check and see! Thanks guys
Old Oct 28, 2008 | 08:25 AM
LSX-PWR's Avatar
Default Re: Having Some Idle/check engine light issues (LSX-PWR)
bump for the day need some help here guys any advice would be great
Old Oct 29, 2008 | 07:37 AM
JDCIVIC's Avatar
it is your map sensor its reading boost while its not suppose to see boost....so all u need to do is get a 2-3 bar map sensor or get the one from an acura rdx
Old Oct 30, 2008 | 09:33 AM
LSX-PWR's Avatar
Default Re: (JDCIVIC)
i figured it had something to do with that. I scanned it with the Honda computer and it wants me to upload new software into the pcm so im gonna try that tonite to see if that works if not im done tryin to tinker with it and not buy it! Thanks
oakman513
Jul 24, 2011 09:31 AM
dkray944
Dec 9, 2008 07:53 PM
Achenar
Oct 2, 2004 01:45 PM
se93
Oct 14, 2002 10:37 PM
