Help With Replacing the Distributor on D15B
Old Oct 27, 2008 | 04:42 PM
Dman03GT's Avatar
Default Help With Replacing the Distributor on D15B
I think I killed my distributor... I was working in there and didn't unplug the battery and arced something and now the car isn't starting.
I have another distributor I want to put on and try, and looking at my chiltons book it says you have to turn the engine over until the #1 piston is at TDC of the compression stroke.
Does that have to be done? How would I know if I am at TDC of the compression or the exhaust stroke?
Help plz.
Old Oct 27, 2008 | 04:53 PM
lillouie18's Avatar
Default Re: Help With Replacing the Distributor on D15B (Dman03GT)
just throw it in it can only go in one way.
Old Oct 27, 2008 | 04:54 PM
crx_si-r's Avatar
if you arced something, check your main battery fuse before you do anything make sure its still good.
Old Oct 27, 2008 | 05:02 PM
Dman03GT's Avatar
Default Re: Help With Replacing the Distributor on D15B (crx_si-r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_si-r &raquo;</TD></TR><TR><TD CLASS="quote">if you arced something, check your main battery fuse before you do anything make sure its still good.</TD></TR></TABLE>
Old Oct 27, 2008 | 05:07 PM
Dman03GT's Avatar
Is that the 50A fuse in the box under the hood? If so I checked all my fuses under the hood and under the dash and all were good.
I also replaced the coil with one I had laying around, and took the igniter to O'Reilly and it tested good, but I got another igniter just to make sure, and that didn't solve it either.
Car just cranks but makes no attempt to start. What happened was I was using a small screwdriver to remove the old distributor cap gasket from inside the grooves on the distributor and near the top where the two wires go into the distributor I had a small arc occur. Ever since then it won't start.
I am thinking I might have fried something internally in the distributor itself? Sator or crank sensor? I don't know if they are electronic or not I'm not too familiar with distributors.
98jdmek
Nov 29, 2007 01:34 PM
civicgsr116
Nov 15, 2007 10:29 AM
ludesrv
May 2, 2006 08:28 PM
vxnine
Jul 25, 2005 03:20 PM
PSU
11
Sep 18, 2003 09:34 PM
