quick b16a2 into eg question
ok my b16a2 has a sensor wich i am assuming is the crank position sensor it is located by the crank pulley under the timing cover my question is obd1 has the crank sensor in the distributor so if i use the b16a2 obd2 distributor with a distribotor jumper harness do i have to extend the sensor that is by the crank pully and splice into the harness i am confused some1 shed some light on this issue please thankx
i am not using obd1 dizzy i am keeping the obd2 dizzy and using a distributor jumper harness so then thinking about it i will have to run the wires and splice correct or just get an obd1 dizzy
sikcrx80
May 1, 2023 05:16 PM
Archidictus
Nov 22, 2007 08:11 PM
Spaceballsthelunchbox
Feb 23, 2007 07:22 AM
