Bouncing Idle and stall after going above 4000rpm, Please Help
Old Oct 27, 2008 | 02:27 PM
RevenantEJ1's Avatar
Default Bouncing Idle and stall after going above 4000rpm, Please Help
After startup my car will bounce idle after I've had it around 4000rpm. It will usually eventually stall. Once I restart it (in the intersection) it is fine. It doesn't seem to do it if I keep the rpm real low (below 3500 or so).
I've tried researching this. Idle air control valve (IACV) seems to come up a lot. Where is this? Clean or replace? Pics or write-up?
Sincere thanks to anyone who can help. This seems to be hurting my motor in some way so I'd like to fix it asap.
Old Oct 27, 2008 | 02:29 PM
Hanmin's Avatar
any cel? could be distributor, tps, iacv, air in coolant.
Old Oct 27, 2008 | 03:16 PM
Default Re: (Hanmin)
Yeah, it's on. I'll pull the codes and reply with the results. Thanks.
95gsr@530
May 13, 2019 10:43 AM
JDM-ish
May 17, 2007 08:13 PM
flatblackintegragsr
Mar 22, 2006 02:39 PM
91SE
Feb 18, 2003 04:35 PM
