axle moves in trans.
Old Oct 27, 2008 | 10:24 AM
fortymcpants's Avatar
Default axle moves in trans.
I have been hearing a noise from my trans. when i accelerate while turning. I thought the axle was bad. when i looked at my passenger side axle today i could wiggle theaxle around in the trans(not in or out, but around). It has about a 1\4" of play. i checked the drivers side and it had very little play, but it is in the halfshaft. I dont think this is normal, so if anyone know what it might be please help me out. thanks.
the tranny is a cable b16
Old Oct 27, 2008 | 10:43 AM
jimmy o.'s Avatar
probably just a worn out cv axle doubt its your trans
Old Oct 27, 2008 | 03:28 PM
itsmejto's Avatar
Default Re: axle moves in trans. (fortymcpants)
could be warn splines or differential output shaft and or bearings/bushings, you'll need to remove the drive shafts to inspect.
Old Oct 27, 2008 | 04:00 PM
Default Re: axle moves in trans. (itsmejto)
any tips on what i should look for in the trans beside the obvious metal shavings and what not. thanks
corpsebesideme
18
Jul 25, 2012 04:16 AM
Mattthepartyboy
May 21, 2012 01:57 PM
project91crxsi
Aug 21, 2009 05:56 PM
eklum
16
Feb 23, 2009 09:02 AM
Cameron60
May 3, 2007 11:00 AM
