Where can I buy metal prongs/pins that go into ECU clip?
Old Oct 27, 2008 | 09:29 AM
Nisif's Avatar
Default Where can I buy metal prongs/pins that go into ECU clip?
I need to add a few wires on a OBD2 engine harness for a gsr swap into a 96 Civic Cx. Is there a part number for the actual metal prongs that attach to the end of the wire at the ecu clip?
I tried using metal prongs from a hacked OBD1 harness however the prongs are a different size for the OBD2 ecu clips.
I was trying to avoid going to the salvage yard due to time constraints, just wondering if there is a part number for these at the dealer. TIA
Old Oct 27, 2008 | 06:31 PM
dtapia's Avatar
Default Re: Where can I buy metal prongs/pins that go into ECU clip? (Nisif)
dealer
Old Oct 28, 2008 | 08:11 AM
Relic1's Avatar
honda dealer - no idea on the part number, they can look it up for you.
local import shop that deals in hondas - common parts needed for a swap.
Old Oct 29, 2008 | 01:35 AM
Nisif's Avatar
Dealer wasn't an option, supposely you'll have to buy the entire wiring harness in order to get the metal pins.
Best bet is to contact Boomslang or Rywire if you don't want to make a trip to the yard, considering they make conversion harnesses and have an adequate supply of the metal pins.
After digging in my garage I lucked out and found a spare OBD2 engine harness that I pulled the pins from.
Old Oct 29, 2008 | 07:20 AM
JOE BD-0's Avatar
check these guys out....not sure about the pins, but they have the plugs, so they should have the pins.......
http://catalog.tycoelectronics...&LG=1
good luck.....
pnapolitano29
Nov 26, 2014 07:30 AM
jdmchickx
10
Oct 26, 2011 06:03 PM
greencivic_0789
May 11, 2010 09:47 AM
Kobal
Sep 15, 2006 05:32 PM
