Automatic Transmission Slipping Question HELP!
Old Oct 27, 2008 | 09:27 AM
BrutalDawg's Avatar
Default Automatic Transmission Slipping Question HELP!
This is my wife's 2000 honda civic ex with around 98000 miles. Recently the D4 Light/Transmission will cut out and it feels like im in neutral for 2-3 sec then it cuts back in to drive, then will cut out periodically and so on. Also a weird funny smell comes out of the vents.
Any suggestions?
Old Oct 27, 2008 | 11:14 AM
BrutalDawg's Avatar
Default Re: Automatic Transmission Slipping Question HELP! (BrutalDawg)
BUMP
Old Oct 27, 2008 | 12:11 PM
94EG8's Avatar
Seagull Management
You can jump the service connector and get the D4 light to flash codes in the same way as you can with a check engine light, i'd try that first. Might be a bad lockup solenoid. Other than that, check the fluid, see if it smells burnt, if its not electronic the transmission is probably bad and will need to be rebuilt or replaced.
JL126
Mar 27, 2014 08:18 PM
Denise W Smith
Honda Civic (2006 - 2015)
Nov 9, 2012 11:05 PM
MACSI360
Honda Civic (2001 - 2005)
Mar 3, 2011 05:12 PM
The1Ash10
Dec 18, 2005 10:46 AM
nc_mx_kid
May 3, 2005 03:24 PM
