stock h22
Old Oct 27, 2008 | 08:56 AM
4Gachilles's Avatar
Default stock h22
can a stock h22 handle 10-15 psi. if not what would i need to build up in order to run a t3 at 10 to 15 psi
Old Oct 27, 2008 | 09:11 AM
98vtec's Avatar
moderator emeritus
Default Re: stock h22 (4Gachilles)
depends on:
engine health
engine management
proper tuning
t3 size and specifications
whats so special about 10-15 psi?
Old Oct 27, 2008 | 09:15 AM
dk4ever's Avatar
Which H22? 10:1 compression can hold 10 psi with a great tune, but not 15. Anything higher than that is on you. I've never seen anyone run more than 9 lbs. on a stock block. The FRM sleeves just can't handle too much abuse.
Old Oct 27, 2008 | 09:25 AM
98vtec's Avatar
moderator emeritus
Default Re: (dk4ever)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dk4ever &raquo;</TD></TR><TR><TD CLASS="quote">Which H22? 10:1 compression can hold 10 psi with a great tune, but not 15. Anything higher than that is on you. I've never seen anyone run more than 9 lbs. on a stock block. The FRM sleeves just can't handle too much abuse.</TD></TR></TABLE>
its not about boost pressure. its about overall power and the tuners knowledge/or lack there of about dialing in ignition timing.
Old Oct 27, 2008 | 09:39 AM
SKDRCR's Avatar
Firedrake was running 14psi on a stock block making close to 400hp.
It held up for a long time.
But that is with AWESOME tuning done on the motor.
Old Oct 27, 2008 | 09:47 AM
dk4ever's Avatar
Wow I stand corrected. We need more ludes out there like that. What kind of tune are they running?
Old Oct 27, 2008 | 09:52 AM
98vtec's Avatar
moderator emeritus
i want to say he was using hondata. I bought the p72 that he used a long long time ago but i cant remember what it was exactly. You can probably just search for his name and get some info.
and i said the things i said because boost pressure doesnt represent an amount of stress the engine is going to be put under. Its basically telling you how hard the turbo is going to be working. The HP range depending on the turbo and the boost pressure will be on very different ends of the spectrum.
Old Oct 27, 2008 | 10:01 AM
SKDRCR's Avatar
Default Re: (98vtec)
Here's a couple of his threads.
https://honda-tech.com/zerothread?id=776298
https://honda-tech.com/zerothread?id=954164
Old Oct 27, 2008 | 01:25 PM
G2IntegraGS's Avatar
And its not the sleeves, its the pistons. The frm sleeves downside is that you have to use special pistons made for frm or resleve the block to use forged pistons.
Drifter6508
May 31, 2013 08:08 PM
solvman
Nov 19, 2004 01:26 PM
tunedbylorange.com
Jan 14, 2004 11:33 AM
tunedbylorange.com
Dec 4, 2003 03:56 PM
DS1
Oct 23, 2002 10:56 AM
