Trans Fluid questions
My 3rd gear is starting to clip/grind again when I take second to redline. The trans has been out once already @ the dealer at 11k miles to have it rebuilt under warranty. The car has 16k on it now. This is not a fault of the car, only my abusive driving style.
Question: What is the best "snake oil" to put in the trans to post-pone the inevitable, pulling it out again.
I would like to hold off at least 2-3 more months and do it in the late fall. I know That the fluid of choice on the board is Honda MTL, but what about short term, cover-up the grinding fluid?????? Redline, Mobil one, Gear oil
thanks Mattj
[Modified by Dropspeed, 9:58 PM 7/29/2002]
thanks Mattj
Stick with the Honda MTF... From all the posts I have read, it is just as good as the others... as for the grinding noise - I am not sure, but, I do not think MTF is gonna help, regardless of what brand. Thats my .02$.
Redline MTL fixes toyota's famous 2nd gear downshift grind in MR2s/older supras/cressidas but not in hondas.
-Dave, who last changed his tranny fluid ~35,000 miles ago and clutch fluid.. never
Honda MTF every ~4,000 miles here.
Brandon - who changes frequently too, but makes a little mess each time...
Will thats an pretty regular...you gotta tool for making that easy?
-jack
-17mm
-drain pan
-10mm socket
-hose with a funnel
-one paper towel
-2.4 qts. of Honda MTF...
Will...tool man...show me the tool...
I made this we-todd set up with a screw-on funnel (to go on the MTF bottle) connected to some hoses that leads to the tranny to fill it up, but I still get a little mess. What do you use.
I agree about the easy part though...easier than oil change.
What do you use.
leave the upper tranny fill plug in place and fill from the VSS hole (ie. 10mm wrench).
I have been using the GM Syncroshift MTF. It seems to work just as good, if not better than Honda MTF. I still like the Honda MTF tho, I always used it in my GSR tranny, and my buddys SI trans.
Try the GM stuff, around 8 bucks a quart tho. I heard it can help some grinding and weird noises when shifting. After I rebuilt my trans recently, this is what I have been using, and it shifts very very smooth into every gear, and has no bad noisies at all.
Guest
Posts: n/a
Is synthetic mobile 1 compliant to honda trannies?
Its Mobile one synthetic gear oil.
[Modified by Jsracingintegra, 7:02 PM 10/21/2002]
thanks Mattj
thanks Mattj
Ask your dealer about the new Honda MTF II.....
for us
Try GM Syncromesh. It lessend my 2nd-3rd grind, and completely eliminated it on a del Sol VTEC tranny (Y21 too, right?).
[Modified by sackdz, 10:03 PM 10/21/2002]
GM Synchromesh
BG Snychroshift
Two different tranny fluids. Both come highly recommended from what I've read.
BG Snychroshift
What do you use.cheepo funnel and ~2' feet of hose to reach up near the intake t00b....
tonight
