My car wont start!
Old Oct 26, 2008 | 06:52 PM
Ecskater1313's Avatar
Default My car wont start!
i got in my car this morning and i stuck the key in the ignition turned the key and i hear a click! all my light are working fine. i don't know what could be causing this! Help me please!
Old Oct 26, 2008 | 06:57 PM
sleepingciv's Avatar
Default Re: My car wont start! (Ecskater1313)
I take it that it doesnt turn over?
could be a bad starter, and bad or loose wire on the battery
Old Oct 26, 2008 | 06:59 PM
it wont turn over but it i keep playing with my clutch when the key is turned it wants to start after a few tries it does.
Old Oct 26, 2008 | 07:01 PM
you mean like pushing the clutch pedal up and down it will start?
there is a safty switch on the clutch pedal
Old Oct 26, 2008 | 07:03 PM
Default Re: My car wont start! (sleepingciv)
yeah when i push it up and down it start. where is the safety switch located?
Old Oct 26, 2008 | 07:06 PM
right above the clutch pedal arm
Old Oct 26, 2008 | 07:08 PM
look at this link its the white plug on the left
http://i47.photobucket.com/alb...1.jpg
Old Oct 26, 2008 | 07:15 PM
so is it like a switch i can switch it on and off?
Old Oct 26, 2008 | 07:16 PM
it turns off and on by using your clutch peddal. it only used to let your car start
Old Oct 26, 2008 | 07:26 PM
ivanson's Avatar
yea if it click when you turn the key most likely your starter and/or
high resistance inside your battery wires, or loose.
my opinion wouldnt really look into that clutch safety switch much.
Old Oct 26, 2008 | 08:13 PM
if i do get it to start can i drive my car without havin it shut off in the middle of the road? oh i forgot to mention this only happens to my car when it is cold out!
Old Oct 26, 2008 | 08:18 PM
KRock459's Avatar
The clutch switch only effects the starter wire, not the ignition or running of the vehicle, once it starts your golden.........dont kill it in traffic
Kirk R
Old Oct 26, 2008 | 08:40 PM
badluckrex's Avatar
Default Re: My car wont start! (KRock459)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KRock459 &raquo;</TD></TR><TR><TD CLASS="quote">The clutch switch only effects the starter wire, not the ignition or running of the vehicle, once it starts your golden.........dont kill it in traffic
Kirk R</TD></TR></TABLE>
agreed
Old Oct 27, 2008 | 08:00 PM
Default Re: My car wont start! (badluckrex)
Thanks!!!!!!
gustafse
Nov 27, 2011 04:55 PM
03K24A4EX
May 26, 2006 04:47 AM
jerBEAR
Oct 31, 2005 10:34 AM
DrewQ1
May 4, 2004 09:14 PM
GroundZer0
Aug 15, 2003 12:05 PM
