Fitting in B18C1 cylinder head, got a quick question
Old Oct 26, 2008 | 04:30 PM
Horizons1's Avatar
Default Fitting in B18C1 cylinder head, got a quick question
I had purchased a 94 B18C1 cylinder head off a local forum. I had the head rebuilt the other day, and the machenist said that the head had a tap with threads in the corner of the head. My only guess is that it for a prior ls vtec setup. My quick question is, can i leave it like that or do i have to plug it. I'm not doing an LS vtec conversion, the head is going on a B18c1 bottom end. Thanks
Old Oct 26, 2008 | 04:32 PM
lluks_844's Avatar
Default Re: Fitting in B18C1 cylinder head, got a quick question (Horizons1)
By lsvtec conversion with a gsr bottom end you mean that your using the ls crank and rods in the gsr?
Old Oct 26, 2008 | 05:07 PM
CTR_B's Avatar
Default Re: Fitting in B18C1 cylinder head, got a quick question (lluks_844)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lluks_844 &raquo;</TD></TR><TR><TD CLASS="quote">By lsvtec conversion with a gsr bottom end you mean that your using the ls crank and rods in the gsr?
</TD></TR></TABLE> Do you know how to read?^^^
You are correct, That was done for a prior ls/vtec conversion. Just leave the plug out and it will be fine.
Old Oct 26, 2008 | 06:17 PM
Horizons1's Avatar
Default Re: Fitting in B18C1 cylinder head, got a quick question (CTR_B)
thanks, so if i leave the tap fitting open, will oil go into the wrong place. I mean what exactly is that for? I just wanna make sure, if i have to throw a plug in there, i will.
Old Oct 26, 2008 | 06:50 PM
CTR_B's Avatar
If you are using a vtec block (B16a/b B17 B18c/c1/c5) and you leave that plug open everything will flow the way it was designed to.
The reason that hole needs to be pluged for the ls/vtec is because Non-vtec block (b18a/b B20) does not have that passage in it.
Just leave the plug out of the head and everything will be fine
Old Oct 26, 2008 | 07:00 PM
Horizons1's Avatar
oh i see what your saying, so let me get this straight, the vtec head has the oil holes for oil flow, but when you want to go ls vtec, you can either weld that hole shut or tap it and put a plug in it to keep oil from coming out.
Old Oct 26, 2008 | 07:02 PM
CTR_B's Avatar
Correct
Old Oct 26, 2008 | 07:08 PM
Horizons1's Avatar
thanks bro
Old Oct 27, 2008 | 10:59 AM
Horizons1's Avatar
the other question is what about the dowel pins for the head. The head was used for a prior ls vtec setup and that means the dowel pin holes were enlarged correct? Well if i'm going back with a gsr head/gsr block setup, and the holes have already been enlarged, what do i use?
Old Oct 27, 2008 | 05:30 PM
lluks_844's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CTR_B &raquo;</TD></TR><TR><TD CLASS="quote"> Do you know how to read?^^^
You are correct, That was done for a prior ls/vtec conversion. Just leave the plug out and it will be fine. </TD></TR></TABLE>
Apparently I do not but you dont got to be a dick. Like u dont make mistakes.
And to the OP the dowel holes dont necesarrily need to be enlarge they may have just used stepped dowel pins like the ones golden eagle makes.
SilverEK96
Jan 24, 2012 03:53 PM
97accord_R
Nov 15, 2008 09:14 AM
1995sir
Apr 20, 2006 07:57 PM
z crx z vtec z
Mar 8, 2002 10:21 AM
Prelussion
Aug 26, 2001 01:30 PM
