Suspension & Brakes Theory, alignment, spring rates....
Strut bars
Old Oct 26, 2008 | 01:48 PM
brandobot89's Avatar
Default Strut bars
My friend was trying to install strut bars in his car from another car. He's wondering can a improper install cause problems? Everything seemed to line up and bolt down good, but he feels as if the rear wheels are shifting side to side at high speeds. Is that normal?
Old Oct 26, 2008 | 01:52 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I can assure you, a shock tower brace will NOT cause the rear wheels to shift around.
I'm assuming the upper shock mount bolts were tightened down properly?
Old Oct 26, 2008 | 02:28 PM
Default Re: (PatrickGSR94)
Yes, they were tightened down with a torque gun to spec. What else can cause shifting of the rear. It feels like it's going shifting left and right. I had an alignment done, everything checks out. I also had a mechanic look at all the rear suspension..
Old Oct 26, 2008 | 04:05 PM
srmofo's Avatar
Default Re: (brandobot89)
Do you mean torque wrench...cause if it was an impact gun then they are not torqued down. what kind of vehicle?
Old Oct 26, 2008 | 04:24 PM
Default Re: (srmofo)
4th gen prelude, it was a 5th gen prelude strut bar. it was a torque wrench, not an impact gun.
buell22
Jan 23, 2008 09:08 PM
Redemption
Dec 5, 2007 04:15 PM
Prudz_lude
Oct 11, 2006 09:07 AM
wizzards581
Feb 10, 2002 08:19 AM
