01 R WONT START
Posting for a friend. Bought a theft recovery 01 R and it wont start. Removed the immobilzer and it still wont start. Switched ECU's and it still wont start. Any suggestions?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BMaDOHC »</TD></TR><TR><TD CLASS="quote">spark, fuel, air?</TD></TR></TABLE>
I'm guessing it could be your distributor . Also check basic thing like spark plug, fuel, etc... If your motor turns and no start up, I'm guessing distributor.
N/m I just saw your post.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mach0 »</TD></TR><TR><TD CLASS="quote">gets fuel( I can hear the pump)
no spark..and we tried a diff distributor</TD></TR></TABLE>
Check your ignition coil.
if it was stolen....y would I try to start it dick...what [freak]ing good is it gonna do me to get the car started if its stolen? am I gonna drive it around stolen...no....*******..
now back on topic..any suggestions
see if it has compression, check the timing belt see if its loose or broken too. if the starter turns hella fast it has no compression. it might have somethin to do with the immobilizer being removed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BMaDOHC »</TD></TR><TR><TD CLASS="quote">probably something with the immobilizer being taken out. try another ecu.
is there any CEL's. check timing.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MazdaSpeedster »</TD></TR><TR><TD CLASS="quote">see if it has compression, check the timing belt see if its loose or broken too. if the starter turns hella fast it has no compression. it might have somethin to do with the immobilizer being removed</TD></TR></TABLE>
IM GOING TO HAVE HIM CHECK..HE USED BOTH A P72 AND A P73...SAME SHYT...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW-ITR »</TD></TR><TR><TD CLASS="quote">Since this was stolen, I bet the thieve(s) F..Ked up the engine. CHECK COMPRESSION! for broken timing belt, bent valve(s).</TD></TR></TABLE>
x2....do a quick compression test and see what you get, then check the timing belt and timing
Happy Gilmore
May 13, 2009 05:21 PM
92EG-SiR
Mar 27, 2008 01:53 PM
boostedpleasure
13
Oct 12, 2006 09:10 AM
i had to say it
