headliner removal?
Old Oct 26, 2008 | 11:13 AM
bigsnorlax's Avatar
Default headliner removal?
Im wanting to know how to remove the headliner and the parts of it that go down next to the windsheild (between window and windsheild). Im doing this cuz im planning on painting/ dyeing it since its vinyl..... but i havent figured out how to remove it. Any hlep is appreciated
Old Oct 26, 2008 | 12:43 PM
Ross 2.0's Avatar
In a Junkyard near you.
Since the car is old you're going to need to replace the clips that hold the panels on. Most of them are probably going to break when you pull the pillar trims off.
You're going to need to remove the seat belt anchors that are held on with one 14mm bolt each. You will need to remove the rear pillar trims, you might need to take the seat back out too which is held in by two 12mm bolts. The handles are held on with Philips head screws as well as the lights which are probably a mixture of philips heads and 8mm bolts. The rest is pretty much just clips. Try to find them somewhere other than honda, they're very expensive from the dealer. I know a company called "Winzer" sells them pretty cheap and they are the same clips.
The headliner itself is held in by velcro and clips.
Any more questions just ask.
Old Oct 26, 2008 | 03:08 PM
bigsnorlax's Avatar
Default Re: (Ross 2.0)
how expensive are the clips?
Old Oct 26, 2008 | 03:42 PM
Ross 2.0's Avatar
Aftermarket are cheap from the dealership they are like $3 a clip
Old Oct 26, 2008 | 03:44 PM
bigsnorlax's Avatar
daaang. But are u saying once i take out the handle screews. light etc. all the bolts n screws do i just pull it down? and the clips should just release/ break? how many clips are there btw?
Old Oct 26, 2008 | 03:49 PM
Ross 2.0's Avatar
I don't have an exact number but probably 30 or so assuming ALL of the clips break.
Old Oct 26, 2008 | 03:51 PM
bigsnorlax's Avatar
jeezzz. thanks for the info. though
Old Oct 26, 2008 | 05:53 PM
Ross 2.0's Avatar
Default Re: (bigsnorlax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigsnorlax &raquo;</TD></TR><TR><TD CLASS="quote">jeezzz. thanks for the info. though</TD></TR></TABLE>
I know it may sound silly and disgusting. But it may be easier to use a giant painters tarp and lots of frog tape and dye it in the car.
Old Oct 27, 2008 | 03:30 AM
bigsnorlax's Avatar
haha yeah thats what i was thinking... but we'll see how it goes
Old Nov 19, 2008 | 01:40 PM
al4490's Avatar
Can anyone tell me how to remove a headliner from a 2000 honda accord sedan? Dang thing has a leak in the roof and I need to fix it.
DAP97SI
Nov 24, 2009 11:26 AM
cadeMFjohnson
Jan 2, 2009 09:27 PM
greaseball
Dec 28, 2004 09:18 PM
Pfieff
Aug 22, 2003 08:22 AM
2LoW4FaThOeS
Aug 31, 2002 08:57 AM
