How can I slow down clear coat peeling?
Old Oct 26, 2008 | 10:46 AM
Importn2oRacer's Avatar
Default How can I slow down clear coat peeling?
I'm kind of in a financial crisis right now so therefore I don't have the money for a new paint job on my 2000 Accord. My clear coat is is getting worser and worser every month/week. What started off as a small spot is now spreading to every other part of the car. Its like a disease And it shows really bad because the OEM paint color is midnight black.
Anyway is there a way to slow down/prevent the process? My car is washed and waxed regularly so some other suggestion than that please.
Old Oct 26, 2008 | 11:00 AM
'95 BA8's Avatar
Default Re: How can I slow down clear coat peeling? (Importn2oRacer)
Pressure wash the rest off LOL
My old Prelude was shedding too
Old Oct 26, 2008 | 12:47 PM
Ross 2.0's Avatar
In a Junkyard near you.
Sand down the areas that are peeling and prime them. That's all that will hold it till you can get it painted.
Old Oct 26, 2008 | 01:27 PM
'00Accordster's Avatar
Default Re: (Ross 2.0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ross 2.0 &raquo;</TD></TR><TR><TD CLASS="quote">Sand down the areas that are peeling and prime them. That's all that will hold it till you can get it painted.</TD></TR></TABLE>
Wouldn't sanding it take the paint off completely?? I'm not sure but isn't there a way to do remove the clear coat completely without taking off the paint.
Don't mean to hijack this thread, its just we have a '95 accord with the same problem.
Old Oct 26, 2008 | 03:47 PM
Ross 2.0's Avatar
Default Re: ('00Accordster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ’00Accordster &raquo;</TD></TR><TR><TD CLASS="quote">
Don't mean to hijack this thread, its just we have a '95 accord with the same problem.</TD></TR></TABLE>
If the clear coat is peeling the underlying paint is probably faded and thin too.
Old Oct 26, 2008 | 04:53 PM
kidcool1977's Avatar
SHAME ON YOU REBECCA!
Community Builder
op, you can go the cheap route and ignore it. I have the same issue on on my trunk lid, look hideous.
Old Oct 26, 2008 | 05:23 PM
99sohcaccord's Avatar
unfortunalty as a body man and painter i have found that honda used a very cheap clear from 90-00 and the paint is very thin under that. as for fixin it u should sand the clear with 400 wet and then use a high build primer to cover the scratches. that should hold for a while but its not a permanant fix. good luck.
Old Oct 26, 2008 | 05:51 PM
Ross 2.0's Avatar
Default Re: (99sohcaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99sohcaccord &raquo;</TD></TR><TR><TD CLASS="quote">unfortunalty as a body man and painter i have found that honda used a very cheap clear from 90-00 and the paint is very thin under that. as for fixin it u should sand the clear with 400 wet and then use a high build primer to cover the scratches. that should hold for a while but its not a permanant fix. good luck.</TD></TR></TABLE>
But that's what a repair technician said. It can't be true!
And it's going beyond 2000 models. I've seen an Accord as new as 2004 with fading paint. You're going to have plenty of business with those.
Old Oct 26, 2008 | 08:20 PM
good for me then i guess huh
Old Oct 28, 2008 | 05:14 PM
crxhondata's Avatar
sand your car with 150 grit than for smooth 320 grit then PRIME THE CAR WED SAND THE PRIMER WITH 2000 GRIT THEN WENT YOU HAVE MONEY to paint the car just paint it
Inextricabledrvr
Oct 20, 2007 03:27 AM
yoyosupmang
Honda Civic (2006 - 2015)
Jun 26, 2007 04:20 PM
tryin_to_be_jdm
Jul 28, 2006 02:38 PM
flipsta
Jul 7, 2004 12:55 AM
xstalkrx
Jun 17, 2004 07:10 PM
