97 Civic EX w/ B18b1, have spark, have fuel, only vtec codes, no start, help!!!
Old Oct 26, 2008 | 09:39 AM
scbmx87's Avatar
Default 97 Civic EX w/ B18b1, have spark, have fuel, only vtec codes, no start, help!!!
Hey everyone, as the topic states I have a 97 Civic EX w/ an OBD2a B18b1 in it. I'm getting spark, i'm getting fuel, but it wont fire. The only code its throwing is #22 for a Vtec pressure valve...which doesn't matter since I don't have vtec. I'm just using a civic EX ecu for right now to make sure the car runs until my jumper harness gets here this week, then i'll be using a an obd1 P75. The car has a DX harness due to not being able to find an EX harness, I did the IACV fix, so its good there. Any ideas on whats going on?? Timing is also fine, i'm lost...
Old Oct 26, 2008 | 11:28 AM
mattscivic1's Avatar
Default Re: 97 Civic EX w/ B18b1, have spark, have fuel, only vtec codes, no start, help!!! (scbmx87)
have you checked your compression?
Old Oct 26, 2008 | 11:53 AM
scbmx87's Avatar
Default Re: 97 Civic EX w/ B18b1, have spark, have fuel, only vtec codes, no start, help!!! (mattscivic1)
No, it ran fine in the last car, its only been sitting for a month or so...
Old Oct 26, 2008 | 01:44 PM
scbmx87's Avatar
Bump, need help.
Old Oct 26, 2008 | 03:57 PM
gsrturboda's Avatar
just wait until u get ur jumper harness, btw u gotta make make sure the distributor is obd1 with obd1 ecu, obd2 dizzy with obd2 ecu
Old Oct 26, 2008 | 06:49 PM
scbmx87's Avatar
Default Re: 97 Civic EX w/ B18b1, have spark, have fuel, only vtec codes, no start, help!!! (gsrturboda)
The dizzy is an OBD1 dizzy rewired to plug into the OBD2 dizzy plug on my harness. So will that work w/ my jumper harness and OBD1 ecu?
Modified by scbmx87 at 8:13 PM 10/26/2008
eM1_kiD
Aug 6, 2013 07:19 PM
B16a2Wa
18
Jan 24, 2010 08:10 PM
B16acivicsedan91
10
Nov 11, 2009 12:23 PM
8YourV8
Jan 3, 2007 09:49 AM
B18C1 '96 Coupe
15
May 23, 2003 06:02 AM
