which soldering gun should I get?
Old Oct 25, 2008 | 09:46 PM
H22CD7's Avatar
Default which soldering gun should I get?
I have a torch that I use for bigger guages but I need something for smaller wires like 12-20 guage because I'm getting ready to do a alarm install, rewire some headlights, and some other little jobs that involve soldering smaller guage wires. So I have narrowed it down to 2 guns at my local hardware store and was wondering which would work best for me. They are both Weller guns, one is a 140/100W gun which heats at 1020 degress at 140W and 900 degrees at 100W and the other gun is a 75W one which heats at 1050 degrees.
Which one would work best for what I need? I like the 75W one better due to the smaller tip but the adjustable heat on the other gun is a nice feature too.
Old Oct 25, 2008 | 10:09 PM
Davus's Avatar
I use the Weller 140/100 gun, and like it enough. But, oddly enough, their $20 single-tip "Therma-Boost" gun is perhaps more enjoyable. (It is a mystery.)
The 75 watt one may leave you wanting more, even on small wires.
EDIT: I changed to a 13 dollar iron, which broke after a few months of abuse. Then I bought the butane torch mentioned below.
Old Oct 25, 2008 | 11:43 PM
imadigitalgod's Avatar
Default Re: (Davus)
I havent i dont do alarms but i am fine with my radio shack 40 watt solder iron, it does even 12/14 gauge with ease
Old Oct 28, 2008 | 04:38 AM
H22CD7's Avatar
Default Re: (Davus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Davus &raquo;</TD></TR><TR><TD CLASS="quote">I use the Weller 140/100 gun, and like it enough. But, oddly enough, their $20 single-tip "Therma-Boost" gun is perhaps more enjoyable. (It is a mystery.)
The 75 watt one may leave you wanting more, even on small wires. </TD></TR></TABLE>
So even though the 75W one gets hotter than the other gun is still might not be quite enough to easily do medium sized wires?
Old Oct 28, 2008 | 08:12 AM
professorman's Avatar
Default Re: (H22CD7)
I have a 30w radio shack soldering iron. I do not know if it is my soldering technique or what, but it is a bit hard to solder. It takes a little while to heat up the wire. I think I paid $7 for it. Do I need a iron with higher wattage? I also just read somewhere that you need to keep the tip cleaned. I did not know about this before, so my tip might be quite dirty.
Old Oct 28, 2008 | 06:16 PM
nsxxtreme's Avatar
Default Re: (professorman)
The 30w irons SUCK!
If your soldering wires the instant on off irons work great. If your soldering electronics invest in a good iron that has a ground probe. Ebay is your best bet. You can pick a Metcal up for less than $200.
Old Oct 28, 2008 | 08:15 PM
Default Re: (nsxxtreme)
I think the 40 watts would b fine at radio shack. I also have a grounded electronics soldder pen from radio shack...worked fine to solder some stuff to an xbox circuit board
Old Oct 30, 2008 | 01:10 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: (imadigitalgod)
i use one of those.. very compact. easy to use under a dash, or tight places.
20 bucks, commonly found at radioshack/fry's.
Old Oct 30, 2008 | 04:57 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: (Built B16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built B16A &raquo;</TD></TR><TR><TD CLASS="quote">
20 bucks, commonly found at radioshack/fry's.</TD></TR></TABLE>
Hey thats mine, lol. This unit works great. I can't live without it. Perfect for honda electrical system.
Old Oct 30, 2008 | 11:44 AM
Built B16A's Avatar
Default Re: (wrx-killer-Sti-eater)
yeah, after i saw yours, went to fry's and picked one up.. used it a few times at work, and decided to buy another for home. the butane lasts forever.. so its deffenetly workable.
noworldorder
Audio / Security / Video
Feb 28, 2007 06:43 PM
00_EJ
Welding / Fabrication
Nov 23, 2006 08:29 PM
d16rice
20
Mar 9, 2005 02:21 PM
RTW DC2R
Dec 13, 2004 07:34 PM
92civicsi
Apr 12, 2003 09:20 PM
