Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
question with 04 accord v6 6spd electrical problem?
Old Oct 25, 2008 | 05:23 PM
rideimport's Avatar
Default question with 04 accord v6 6spd electrical problem?
Hope someone will help me out... I don't if you guys experience this w/your accord
'04 accord v6 6sp coupe
Just recently the remote to my car stopped working. When i press down on the unlock/lock/ or trunk icon, the red light blinks but it would not unlock or lock my car.
Also, the automatic door does not work when i take my keys out. So now, i have to open my car with the key in it, then reach over to the passenger side to unlock the door. Such a hassle, i haven't made it to the dealership to check it out yet.
Just want to see what you guys think.
Thanks
Old Oct 26, 2008 | 12:55 PM
Ross 2.0's Avatar
In a Junkyard near you.
If you manually lock the drivers door will the remote work? A few things can cause this.
#1 a weak remote battery (most likely considering age)
#2 a failed drivers door lock actuator (second more likely) The power locks will not work right if the drivers actuator has failed.
#3 a bad drivers door switch (equally as likely) (push the black button, if there is no resistance you can pop it out and snap it back together)
#4 a failed drivers multiplex unit (least likely) this unit controls all of the systems you are having issues with.
Old Oct 26, 2008 | 05:15 PM
rideimport's Avatar
Default Re: (Ross 2.0)
thank you for the reply, it was really helpful.
the remote does not work at anytime.
i'm gonna take it to the shop and have them take a look.
Thanks
Old Oct 26, 2008 | 05:48 PM
Ross 2.0's Avatar
do yourself a favor and at least check the door switch 1st if nothing else. it's a free fix if that's the case.
Amandaapples
Sep 11, 2024 01:51 PM
stereobumps
Jun 19, 2017 08:13 AM
chiboy162
Nov 15, 2016 07:37 AM
CaspianSeayaker
Feb 8, 2015 07:00 PM
kmy
Dec 22, 2009 05:54 AM
