Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
08 si guage installation...
Old Oct 25, 2008 | 02:02 PM
SImadness's Avatar
Default 08 si guage installation...
im installing an autometer a/f meter on my 08 si sedan. ive came across the question they are more accurate with a wideband o2 sensor. do our civics being so new have wideband o2 sensors?
i have already searched and nothing.. tHANKS
Old Oct 25, 2008 | 04:28 PM
Zeusone's Avatar
if im not mistaken you would have to add another o2 sensor on your exhaust to make it work that way.
Old Oct 25, 2008 | 09:25 PM
pd0019's Avatar
Default Re: (Zeusone)
place it pre-cat above the middle line of the pipe...basically so that it is parellel to the ground.
i think the new civics have a wideband but just have a new hole made.
Old Oct 26, 2008 | 02:37 PM
dirtySOHC's's Avatar
Default Re: (pd0019)
even if the civic was equiped with a wideband sensor the meter would have to be clalibrated to give give correct readings from the sensor.
i dont know if the newer civics have wideband sensors or not but i doubt it. honda uses narrow band sensors for better fuel efficiency.
Modified by dirtySOHC's at 7:35 PM 10/26/2008
Old Oct 26, 2008 | 04:10 PM
vladd's Avatar
Default Re: 08 si guage installation... (SImadness)
that autometer a/f gauge won't tell you ****. don't waste your money. if you actually need to know your a/f ratio get a wideband o2 sensor and the proper gauge to go with it.
Old Oct 26, 2008 | 06:32 PM
pd0019's Avatar
Default Re: 08 si guage installation... (vladd)
^ good point. go with AEM or innovate
Old Nov 19, 2008 | 09:04 PM
SImadness's Avatar
perfect guys thanks for the help!
Pellegrini808
May 31, 2014 12:03 PM
Mr Hammond
May 2, 2004 09:54 AM
djnikko
Nov 5, 2003 05:44 PM
hwoody77
Oct 30, 2003 09:10 AM
TriK
Aug 24, 2002 07:38 AM
