How do I adjust the hood latch?
Old Jul 29, 2002 | 03:42 PM
B2FiNiTY's Avatar
Default How do I adjust the hood latch?
How do I adjust the hood latch? I want to set it lower to see if the C/F hood will fit better. Thanks in advance.
I already took off the 3 10mm bolts holding it to the radiator support.
Old Jul 29, 2002 | 03:46 PM
newspeedR's Avatar
Default Re: How do I adjust the hood latch? (B2FiNiTY)
there should be slots in the latch that you can slide it up or down...
or you are going to have to make slots... use a dremel or a drill to slot
as long as you need...
Old Jul 29, 2002 | 04:12 PM
B2FiNiTY's Avatar
Default Re: How do I adjust the hood latch? (newspeedR)
It was easier than I thought.
It's 3 10mm bolts that you just loosen and then you can move the hood latch up and down.
Old Jul 29, 2002 | 06:09 PM
SoCal ITR's Avatar
Good question....
:goes to adjust his so he doesn't have to slam the hood....:
Lightsped
Aug 14, 2008 10:02 AM
Francesco
Honda S2000
Jul 22, 2006 06:16 PM
sutrusu
Oct 26, 2005 11:20 AM
the DA in HONDA
Sep 22, 2004 06:39 PM
