Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2008 accord coupe navi wiring vss and reverse plz help
Old Oct 25, 2008 | 11:13 AM
ptamarin's Avatar
Default 2008 accord coupe navi wiring vss and reverse plz help
Hi,
I am wiring up a avic-f90bt myself, its going well i have almost everything sorted out including the steering wheel controls hookup.
the parking parking wire is attached to the parking brake lever afaik
I need some help locating the vehicle speed sensor wire and the reverse signal wire.
For previous years accord i have heard they are a certain wire and pin on the pcm below the driver dash. I am not sure if this changed for the 2008 accords
Old Oct 25, 2008 | 12:56 PM
ptamarin's Avatar
Default Re: 2008 accord coupe navi wiring vss and reverse plz help (ptamarin)
Solved information here for other peoples use
12 VOLTS White Ignition switch harness +
IGNITION Blue Ignition switch harness +
ACCESSORY Orange Ignition switch harness +
STARTER Yellow Ignition switch harness +
KEY SENSE Pink Ignition switch harness in white plug -
TACH SIGNAL Opposite from Black/white or Blue At any of the coils on the engine AC
FUEL INJECTOR Opposite from Yellow/black At any injector on engine AC
LOCK Orange At switch in driver door -
UNLOCK Brown At switch in driver door -
Double pulse to disarm and unlock.
DOORPIN SEE NOTES
Green (Driver's door), Lt.green (pass. Door), Brown (Rear left) and Gray (Rear right). All 4 wires are (-) and found in the green 42-pin plug on the top of the fusebox under the driver's side of the dash.
HOODPIN Lt.blue or Yellow/red At pinswitch or front of fusebox -
Not available on all models.
TRUNK PIN Blue or White In green 42-pin plug top of fusebox -
TRUNK RELEASE Orange In green 42-pin plug top of fusebox +
FACTORY ARM Arms with lock
FACTORY DISARM Disarms with unlock
BRAKESWITCH Green At brake switch +
PARKLIGHTS Gray In green 42-pin plug top of fusebox +
HAND BRAKE Lt. Green At parking brake switch -
HORN Green/yellow In green 42-pin plug top of fusebox -
HEADLIGHTS Pink At light switch harness -
REVERSE LIGHTS Brown In driver's kickpanel +
VSS WIRE Blue In plug on back of radio AC
TRANSPONDER DATA 1 Lt.Green Pin-3 at 7-Pin connector DATA
Old Oct 27, 2008 | 05:10 AM
hondaracer4vtec's Avatar
Thanks Ptamarin
Nice write up
Old Oct 27, 2008 | 05:15 AM
MSchu's Avatar
My Name is Nobody
Does the manual back up this information? If so I will sticky this post
Old Oct 27, 2008 | 06:34 AM
Ross 2.0's Avatar
In a Junkyard near you.
I'll check but I only have the preliminary manual right now, it's going to take a bit...
F22B Accord
Apr 21, 2014 03:00 AM
Rand The Man
Audio / Security / Video
11
Aug 15, 2012 11:50 PM
Hanmin
Sep 19, 2008 06:07 AM
phillybeats.com
Jun 25, 2004 06:47 AM
