94 LS--radiator and condensor fans not running
Old Oct 25, 2008 | 10:50 AM
WERA689's Avatar
Default 94 LS--radiator and condensor fans not running
As stated...neither fan is coming on at all. The cooling system is working, but temps indicate 1/2 scale on the gague, instead of less than 1/4.
I checked all fuses, and swapped the relays in the underhood fuse box, still no results.
Anyone have any ideas for troubleshooting/tracking down the problem?
Thanks!
Old Oct 27, 2008 | 01:06 AM
WERA689's Avatar
Default Re: 94 LS--radiator and condensor fans not running (WERA689)
Update:
Both fans will run, IF I have the A/C running. If I cut off the A/C, both fans stop. The radiator fan seems unwilling to run by itself.
Temps seem to stabilize at about 1/2 scale now, whether the fan is running (w/A/C) or not.
I just know someone out there has had the same problem...right?
Old Oct 27, 2008 | 05:05 AM
weavertime1's Avatar
Check your thermostat. Sometimes if the thermostate gets stuck your carw ill run warmer than usual and it will not let antifreeze reach the coolant temp. sensor which would prevent the fan from turning on. Good luck!
Old Oct 27, 2008 | 09:19 AM
WERA689's Avatar
Default Re: 94 LS--radiator and condensor fans not running (weavertime1)
It did seem to take a long time for the lower radiator hose to get hot....does this also point to the thermostat?
Old Oct 27, 2008 | 09:28 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WERA689 &raquo;</TD></TR><TR><TD CLASS="quote">It did seem to take a long time for the lower radiator hose to get hot....does this also point to the thermostat?</TD></TR></TABLE>
Yes it does.
Old Oct 27, 2008 | 06:20 PM
WERA689's Avatar
Thank you, sir. I have picked up the thermostat and will be installing it tonight!
Kenneth723
Jun 9, 2019 07:38 PM
evokiller666
Jan 23, 2009 06:46 AM
aznlaoboi315
Mar 13, 2008 02:35 PM
Donhonda84
Apr 4, 2007 08:36 PM
subgeniusdude
Jun 19, 2005 05:43 PM
