CRX flooded and now it wont start. Code 0?
Old Oct 25, 2008 | 10:15 AM
CoolRedXylophone's Avatar
Default CRX flooded and now it wont start. Code 0?
My CRX was flooded last night. The water was up to the bottom the door speaker covers inside the car. My Batt is good, there is no water in the intake, the oil doesnt look any different, and the engine turns over. The Check engine light is on obviously and the ECU light just stays on when the key is turned to on. Code 0 i believe. So is the ECU fried most likely or could the harness just be too wet? Also is there any good way to tell if there is water in my motor by looking at the oil? The oil looks normal but im not sure. THANKS
Old Oct 25, 2008 | 11:07 AM
sleepingciv's Avatar
Default Re: CRX flooded and now it wont start. Code 0? (CoolRedXylophone)
Ya your correct code 0 is ECM. I would take the computer out take it inside the house open it up and let it dry out. Get a wet/dry shop vac and suck as much water out of the car a poss. pull back the carpet with the computer is and take a small portable heater or hair dryer and dry the heck outta it.More then likley when ya tried to start the car you might have fried the ecu.
also check all fuses under the dash and under the hood.
Ya said the water only went up to your speakers so i dont see how any water would make it into the motor.
What ecu do you have?
gnxpro24
Transmission & Drivetrain
Apr 21, 2011 03:16 PM
slowFTW
Oct 18, 2009 07:45 PM
Ak_ef9
Sep 27, 2008 12:50 PM
93sihatchy
15
Aug 19, 2007 07:57 AM
hecktabite
May 24, 2002 09:51 PM
