94 Accord Auto, Shifts really hard!!!
Old Oct 25, 2008 | 08:51 AM
LSR-Abuser's Avatar
Default 94 Accord Auto, Shifts really hard!!!
Anyone know if there is a way to adjust how the auto trans shifts.
Old Oct 25, 2008 | 09:43 AM
hondadude's Avatar
Default Re: 94 Accord Auto, Shifts really hard!!! (LSR-Abuser)
The only adjustment is the pressure lever cable , that goes from the throttle linkage to the front of the trans.
A better definition of "SHIFTS HARD" might get you some other suggestions.
do the rpms rise way up between shifts?
If you are a first time owner, you should understand that the honda trans of those years shifts under positive pressure of the clutch paks
Old Oct 25, 2008 | 11:12 AM
LSR-Abuser's Avatar
Default Re: 94 Accord Auto, Shifts really hard!!! (hondadude)
Ya I never owned a Auto before,it does not slip it just shifts really hard,it's worse when it cold and gets a little better when it's warm.I bought the car with a bad trans,I pick up aone form a JDM motor dealer and change it,just trying to see if this is normal to shift hard.
Old Oct 25, 2008 | 11:22 AM
P_Adams's Avatar
No, a really harsh shift is abnormal in most all circumstances.
There is an accumulator assembly:
http://www.hondaautomotivepart...+BODY
who's job is to cushion the shift application. Perhaps you have an issue here...
Here is an illustration of the afore mentioned Throttle Pressure Cable. Check and make sure you don't have an issue there.
http://www.hondaautomotivepart...LEVER
P
wapperjaw1
Dec 28, 2016 09:15 AM
trickeng
Apr 18, 2015 10:17 AM
tamadrummer1120
Apr 21, 2009 12:07 PM
Augie56
Mar 3, 2008 05:19 AM
