Need help with my new DA
Old Oct 25, 2008 | 07:17 AM
felixjr18's Avatar
Default Need help with my new DA
Ok I bought a 92 integra with 185,xxx miles and im not sure if I should rebuild it or swap it with a lower mileage b18a1 or jdm b16? I so I added headers downpipe and hi flo cat and had to add 2"inches of pipe because it didn't reach the exhaust and now its hitting the heat shield when I down shift or go over bumps?
Modified by felixjr18 at 7:18 AM 10/26/2008
Old Oct 26, 2008 | 10:30 AM
felixjr18's Avatar
Default Re: Need help with my new DA (felixjr18)
Can anyone help me please!
Old Oct 26, 2008 | 10:48 AM
stocker2shocker91's Avatar
I requested a short story for a title.
well how does the engine run? smoke? rough idle? compression?
if everything checks out there is not really a need to swap it.
it all depends on your plans for it which are??
Old Oct 26, 2008 | 01:39 PM
Da9Gro's Avatar
Default Re: Need help with my new DA (stocker2shocker91)
as the old say goes,"If it ain't broke, don't fix it."
Old Oct 26, 2008 | 05:59 PM
The G2 Racer's Avatar
Default Re: Need help with my new DA (Da9Gro)
With mileage that low, if the motor is good I wouldn't swap it at all. Boost it make.
B16 in a DA is pointless unless it's an RS model (less weight). My GS-R has a B16 and the B17 seems to be more powerful in my mind.
Old Oct 26, 2008 | 07:25 PM
felixjr18's Avatar
The motor runs fine still is decent and doesn't blow any smoke.. It idles right under 1g and i've never done a compression test on it.. The only this wrong is theres valve chatter but it still runzs smooth. My plans are to turbo it and keep it as a daily driver. All seals have been replaced so there are no leaks of any sort I was jus wondering with the mileage if it was safe to boost and make decent power (250-300)
Thank for the advice
Old Oct 26, 2008 | 08:06 PM
lilvietboy's Avatar
yeah if it works dont needa buy something new
my b18a1 has 222XXX miles running strong.. once it blows i think im gonna get a nice gsr motor in there=]] or maybe an ITR when time comes=]]
id say just keep it until it blows and save your money and buy a b18c 1 or 5 depends on how much ya got saved=]]
Old Oct 26, 2008 | 08:11 PM
Brice.Hayden's Avatar
Default Re: Need help with my new DA (The G2 Racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The G2 Racer &raquo;</TD></TR><TR><TD CLASS="quote">With mileage that low, if the motor is good I wouldn't swap it at all. Boost it make.
B16 in a DA is pointless unless it's an RS model (less weight). My GS-R has a B16 and the B17 seems to be more powerful in my mind.</TD></TR></TABLE>
why is it pointless?
i got a low mileage b16 to replace my old LS and i got 30+ MPG and i had more HP. seems fine to me.
Hell DA with b16 &gt; Civic SI with b16
ej1vtec5668
Apr 27, 2009 06:47 PM
StingRay4
Feb 14, 2007 09:00 PM
streetinformer
Mar 17, 2005 11:34 AM
SkoundrelUSA
15
Sep 20, 2004 09:35 PM
cannondale
Oct 24, 2001 11:19 PM
