Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Has anyone experienced this problem or know how to fix?
Old Oct 25, 2008 | 05:33 AM
USMarine's Avatar
Default Has anyone experienced this problem or know how to fix?
I have a 2003 Honda Accord. When the heat is turned on (both are set to HI and AC is turned OFF), hot air blows on the passenger side 120-130 degrees and 60-70 degrees is blown on the drives side. I had it looked at by honda in my home town. They cannot figure it out because all of the gates are opening & closing when you adjust the tempeture controls. The heater core was backflushed twice. I thought maybe fresh air vents could be pulling cold air in. I live in MN and it is cold outside. I plugged all the fresh air vents that I could find and that didn't work. Can anyone give me some advices or have you experienced this problem?
Old Oct 25, 2008 | 10:29 AM
White V6's Avatar
Default Re: Has anyone experienced this problem or know how to fix? (USMarine)
Well pulling the fresh air vent wouldn't cause this. I think you look for a blend door motor that's still work, but has been stuck and the motor tried to move it and stripped out were the motor connects to door. That's what it sounds like to me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USMarine &raquo;</TD></TR><TR><TD CLASS="quote"> I had it looked at by Honda in my home town. They cannot figure it out because all of the gates are opening & closing when you adjust the temperature controls. </TD></TR></TABLE>
I think what the dealer did was hook it up to there scanner and commanded the doors to open and close. The motor works but the door stuck. I think that's why they couldn't find anything.
Hope this helps
Old Oct 28, 2008 | 03:51 PM
USMarine's Avatar
Default Re: Has anyone experienced this problem or know how to fix? (White V6)
Is it a blend motor or are you saying a temperature control motor? Where is the blend motor located? The doors are opening fine visually. Thanks.
Old Oct 28, 2008 | 07:32 PM
Ross 2.0's Avatar
In a Junkyard near you.
It's still the heater core. The same thing happens on CR-V's and Elements. We don't have the capability of commanding the blend doors with the HDS.
What you CAN do is run the self diagnostic on the climate control and see if you get any DTC's
I doubt you will find any though.
http://www.flickr.com/photos/moogocow3/2982558545/
http://www.flickr.com/photos/moogocow3/2982558379/
Old Oct 29, 2008 | 09:50 AM
NGUSPEED's Avatar
Default Re: (Ross 2.0)
That's pretty neat.
I'll probably never use it, but it's good to know
Old Oct 29, 2008 | 11:49 AM
White V6's Avatar
Default Re: (NGUSPEED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ross 2.0 &raquo;</TD></TR><TR><TD CLASS="quote">It's still the heater core. The same thing happens on CR-V's and Elements. We don't have the capability of commanding the blend doors with the HDS.</TD></TR></TABLE>
My Bad
jcolbert665
Dec 2, 2016 08:18 AM
hoffmanp
Aug 13, 2014 08:59 PM
aust 97 coupe
Jan 3, 2009 05:21 AM
TekNinja23
Jul 11, 2003 08:26 AM
