New motor won't crank. Timing?
Just got done with my first swap. Old y8 threw a rod so i got a y7 block rebuilt. well i've got everything together now but the car won't crank. It has spark and fuel pressure. I tried some starting fluid in the intake. It will turn over all day long but no crank. Any ideas?
If one or more cylinder has substantially lower pressure than the others, then you likely have identified the no-start cause. You can add oil to the cylinder during the test -- if the pressure increases, then the piston ring is bad. You can also do a leak down test to identify other potential causes:
http://www.geocities.com/dsmgr...n.htm
If cylinders are unable to hold pressure, then the force of the combustion cannot turn the engine. Related to this idea, is your engine possibly flooded.
Also check whether your mechanical timing is off, that is whether the cam and crank are not synchronized at TDC1.
interestingly enough, the thermostat housing wasn't grounded. but that didn't solve the problem. I've been trying to find a write up about checking the mechanical timing. does one exist here?
bump. need some help. gotten it to start twice.. both times barely ran for a very short amount of time and died. when giving it a little gas trying to start it will try very hard to crank but won't get going all the way. catches and fires all cylinders i believe, but won't go all the way. any ideas?
should mention that this car sat for nearly a year before now.
You need to know the difference between cranking and running and you're not helping much by running two diferent message threads on the same problem.
Modified by itsmejto at 11:33 AM 10/26/2008
have we even checked by putting a screw driver in the end to see if your getting spark if so u should know ur getting fuel if the plugs saturated when u pull it. maybe re check ur cam timing and has it had a valve lash?
MI4$DC5
Mar 12, 2007 05:59 PM
so it's possible that it's buggered. already tried the distributor as many ways as i could.
