another swap and car wont start thread
Old 03-12-2007, 11:16 AM
MI4$DC5's Avatar
Default another swap and car wont start thread
1994 DX eg
b20vtec. gsr head/b20 bottom end.
I dropped it in and wired everything up and the car will not start. I had a CEL but it was for iat. i think i had the wrong plug init. so i switched it out and no i have no CEL. The car cranks but will not turn over. I checked the plugs and im getting spark. Im getting fuel. im going to double check it again today. I dont know where the problem is.
Old 03-12-2007, 11:27 AM
choppedndropped's Avatar
ummm. doesn't crank mean the same thing as turning over? Check your timing.
Old 03-12-2007, 11:31 AM
pdiggitydogg's Avatar
my build is doing the same thing right now - crank but no start
Timing belt is off on mine though
Have you checked compression?
Old 03-12-2007, 03:31 PM
MI4$DC5's Avatar
Default Re: (pdiggitydogg)
yeah i checked the compression on it yesterday and im getting 270-260-270-280 across the board. so im good on that. how can i adjust the timing besides at the dizzy? yeah it cranks but doesnt turn over though.
Old 03-12-2007, 04:42 PM
Slurp56's Avatar
Default Re: (MI4EH2)
You want to make sure that your cams are in time with your crank.
If you have adjustable cam gears, reset them both to "0". Using the pistol sight on the lower timing cover, line up the TDC mark on the crank pulley. The TDC marks on your cam gears should also match at this point. For your distributor, notice that the bolt holes are slotted. Loosed the bolts and center the distributor slots around the bolts. That is close enough to get you started. Also double check your firing order. If the spark plug wires are not in the correct order, your motor will not run, Either at all or happily.
Old 03-12-2007, 05:59 PM
MI4$DC5's Avatar
Default Re: (Slurp56)
alright thanks, im going to check that out right now.......
MitchHamilton
15
10-25-2016 05:00 AM
sunnyutahsky
08-10-2013 06:32 PM
Happiest92Ricer
12
06-28-2013 08:52 AM
lt1guy
02-14-2010 07:06 PM
mygfs92lx
07-19-2006 06:33 PM
Quick Reply: another swap and car wont start thread
