What's the function of a subframe on a car? How much would it take to tear this on a 95 ex coupe?
Old Jul 29, 2002 | 03:13 PM
95civiccoupe31's Avatar
Default What's the function of a subframe on a car? How much would it take to tear this on a 95 ex coupe?
I have a 22mm swaybar and my car is dropped about 2.75 inches. When would i look into changing parts to strengthen this? I rarely autocross.
Old Jul 29, 2002 | 03:15 PM
DSC's Avatar
DSC
Default Re: What's the function of a subframe on a car? How much would it take to tear this on a 95 ex coup
http://www.beaksproducts.com
Their subframe kit.
Old Jul 29, 2002 | 03:17 PM
Spade's Avatar
THe LCA's connect to it. The lower strut bar (rear tie bar) attach to it.
U shaped thing in the middle. Search would give you pictures I promise.
Old Jul 29, 2002 | 03:25 PM
O.k. i have a progress rear 22mm sway bar that has been welded on. I should be fine right? How would i know that the subframe has teared? Would i be in deep **** if this ocurred?
Old Jul 29, 2002 | 03:28 PM
Spade's Avatar
Yeah you wouldn't be very happy if it teared. Do you know where it was welded?
Old Jul 29, 2002 | 03:36 PM
I would assume the lca's but i would have to take a peak...the thing shakes like a **** though. Chances of this occuring would increase if i was taking hard turns on a track or the street at high speeds right? If i was to drag only (aside from highway driving) i wouldnt run into to0 many problems right?
Old Jul 29, 2002 | 03:40 PM
Spade's Avatar
Do you have a digital? Pictures of this would be very helpful.
Theoretically if it is welded on properly it should do more than fine racing but, it depends on the weld quality.
Old Jul 29, 2002 | 03:47 PM
o.k. i looked under the rear of the car...the bar itself is welded onto the subframe...it look substantially done.
Old Jul 29, 2002 | 03:49 PM
Spade's Avatar
The bar is usless have it removed.
If it cannot pivot or swival with the brakets on the subfram then it doesn't help and actually harms performance.
Old Jul 29, 2002 | 03:55 PM
JV's Avatar
JV
Who?
This is the setup on my 95 EX:
GSR lca's
22mm ITR sway
Beaks SRK
In the pics you can see where the beaks kit reinforces the subframes.
Whatever your friend did. Have him undo it...
Old Jul 29, 2002 | 05:26 PM
stevecockrill's Avatar
Nice. Same thing on my del Sol.....del Sol VTEC LCA's though......and LCA tie bar.
Steve
Old Jul 29, 2002 | 06:00 PM
kefka's Avatar
beaks mang..
[Modified by feint_style, 7:01 PM 7/29/2002]
Old Jul 29, 2002 | 06:17 PM
underrated99si's Avatar
Steve
aaaaaa Progress Coilovers the best mod I ever did besides there swaybar
Old Jul 29, 2002 | 06:35 PM
you guys are right..i looked again and its not welded to the subframe its welded to the lower bolt in this picture...(the bottom part of the bushingbolt in this picture..it hangs down a lot too...i dont like how it wraps around either. I will purchase the beaks 22mm itr sway bar and reinforcement kit with my insurance money asap. THanks guys i appreciate it a lot. 175 is a great price too. If you want to see what i am talking about further than someone post a pic of their progress rear sway bar. I believe the mounting hardware sucks *****! Do you guys reccomend their lower tie bar upgrade kit too? Now their website shows the subframe reinforcement kit too....what is this for? Do i want this? They say its for the DC and EG chassis's i have an ej so im assuming the eg would be me?? Thanks guys
[Modified by 95civiccoupe31, 10:40 PM 7/29/2002]
[Modified by 95civiccoupe31, 10:44 PM 7/29/2002]
[Modified by 95civiccoupe31, 10:45 PM 7/29/2002]
Old Jul 29, 2002 | 07:10 PM
ttt
Old Jul 29, 2002 | 08:01 PM
?tttttt
lazycamper
Oct 6, 2014 02:13 AM
H22Ej1
Suspension & Brakes
Apr 27, 2008 10:30 PM
pjr710
10
Apr 16, 2006 04:41 PM
agent marlon
Oct 13, 2002 05:07 PM
image-evo1
Apr 7, 2002 11:02 PM
